Motor Mounts for LS1 swap
I read a few of the posts that involve the LS1 swap into a C3. I am looking for motor mounts that move the motor 1" forward. I am using a T56 so I would like to get shifter close as possible to centered in the console. Those that have done the swap what mounts are you using? Links would be appreciated? I did search and I did read but some said this and others said that... so i thought i would ask. thanks.
If you are building a custom console you can locate the shifter in the middle if you prefer. I used a factory Hurst shifter, did some measuring, and cut a plate for the offset needed for the stock location.
Rick B.
