1981 Power Antenna Repair
Following on from a previous thread....
Antenna was stuck in the up position so I decided to remove it to see what the problem was.
On closer inspection, all 3 wires had been cut. When these were connected back up ( no key in ignition and so radio off ) the motor ran continuously but the mast stayed up. Whne green wire disconnected, it stopped.
I removed the antenna and stripped it down.
In the antenna housing, the hook and a short length of the nylon inner rod could be seen, Im guessing at 4-5 inches max.
There is no nylon inner coming out of the bottom of the mast.
Mast is straight and not bent.
So, what repair kit do I need? Is the mast and nylon inner one piece or are they separate? If separate, how do I get the remaining nylon inner out of mast?
Also, would I be right in thinking that the motor ran because it was as if the mast was coming down but as the inner had snapped, it just ran on and on?
Cheers.
Cheers.
Dumb question, how do I get the old mast out of the tubing?
The tubing out of the mast you mean...LOL I did it on my 82 but I don't remember how it attached. I do know it was very easy. The hardest part was winding the nylon on the spool and closing it up.
Try closing the mast all the way and I think it pops out the bottom. Then you'll see how it attaches.
Ah, it's easy when you know how.
With a little help from KapsSA it became clear. The small finial on the end of the mast unscrews and then you simply pull the top section of the mast out with the nylon leader.
Now just need to source a new part.
