Speedometer gear 68
Old 08-20-2013, 10:59 PM
cdj46
cdj46's Avatar
Default Speedometer gear 68
I am looking for the correct speedometer gear for my 68 427 4 speed, 3:36 stock tires. Is there a chart that will tell me color of gear and # of teeth?
Chuck
Old 08-21-2013, 12:21 AM
DZRick
DZRick's Avatar
Follow this link then click on ( Supporting document )
http://willcoxcorvette.com/repairand...lp.php?hID=131
I guess they only list the part numbers, sorry.
Old 08-22-2013, 12:46 PM
cdj46
cdj46's Avatar
I did some more research. My car has a blue 20 tooth gear as it should be per a calculation on web site. Problem is the car reads 70 MPH when I think I am going ~40.
Old 08-22-2013, 01:26 PM
Billem
Billem's Avatar
I have no idea if this will help, but I've found that a 1 tooth change is worth approx. 5mph. (I.E. In my case, Speedo reading = 60, actual = 65; needed to go DOWN 1 tooth less). In your case, I believe there is something else wrong 'cause a 26 tooth gear is a little unusual, but who knows? BTW, the easiest way to check the speedometer is with a GPS. Have a great day, Bill
Old 08-22-2013, 08:36 PM
cdj46
cdj46's Avatar
Default Speedo
Thanks Bill I never thought of GPS. I will try it.
Chuck
To Speedometer gear 68
Quick Reply: Speedometer gear 68
