Headlight shakes and giggles
Old 09-02-2013, 09:18 PM
c3dreamer03
c3dreamer03's Avatar
Default Headlight shakes and giggles
Car is a 1976. The driver's side headlight has movement from left to right if I when I move it. The passenger side does not. It appears that the drivers side is bouncing as well when driving down the road. I don't so much notice the headlight assembly bouncing, but I can see the beam projected on the road moving.
What is common cause of left and right movement and bouncing up and down after hitting a very small bump in the road? What's the fix?
Thanks.
Old 09-02-2013, 10:06 PM
Arkyvette
Arkyvette's Avatar
I have this issue. I'm thinking the springs might be weak on my bulbs. Either way, I'm subscribed....
Old 09-02-2013, 10:59 PM
blitz10
blitz10's Avatar
My 72 was the same way, ended up the plastic bushings were missing, thus causing movement in the light assembly. Suppliers sell a kit for the plastic bushings and sleeves. Mine came for Corvette Central.
To Headlight shakes and giggles
Quick Reply: Headlight shakes and giggles
