79 Fuse Panal Help
79 Fuse Panal Help
Hi All, Had to renew the turn signal flasher on my 79. There was a
"condenser looking" thing that had a pigtail close to the flasher and
the condenser thing came loose from the fuse panel. It is a yellow colored "condenser? with two pigtails with spade connectors that plugged into the fuse panel. I can not figure out where to plug it back into the panel. When I looked up fuse panels for a 79,there is no condenser looking item there, do I need this thing???
No aftermarket add on items in this car either,Iam more confused
than normal. Any advise?
