383 stroker questions
Old 10-15-2013, 09:54 PM
tonymwc
tonymwc's Avatar
Default 383 stroker questions
Debating on doing a 383 stroker kit on my 75. If I do, what are some of the better kits out there? Just bought my 75 and I need more power! Or if there are better options feel free to educate me!!!!!
Old 10-16-2013, 12:29 AM
bluedawg
bluedawg's Avatar
Scat or callies with Stroker clearance rods.
Old 10-16-2013, 04:34 PM
CheezMoe
CheezMoe's Avatar
St. Jude Donor '11-'12-'13,'19-'20
I used Scat 9000 crank (very cost effective for street use), Scat 4140 i beam stroker rods with ARP bolts, and Diamond Racing forged pistons (seduction and overkill for street).
If you are going to do 383 dont make the same mistakes I made on my first attempt:
1. Use some big port heads or the extra cubes wont get you much. I tried to port some GM iron 882 heads and it was choked up pretty bad.
2. Use a nice hi performance roller cam to go with those heads. I started with a Comp XE 268. Not a good choice!
I think my original head and cam combo would have been fine for 327/350 I think but not enough for the stroker and I was initally dissapointed. I upgraded to Howards Roller Cam and RHS pro-action aluminum heads and now she
Im sure others will chime in but this is my .02 today! Good luck!
Old 10-16-2013, 05:28 PM
MSGT-R
MSGT-R's Avatar
I bought a kit from Keith Black years ago on an end-of-race-season sale, and put it on the shelf (building a junk yard refugee).
Whatever kit you use, it is not a "drop in". The block must be clearanced for the larger counterweights and rod stroke. Certain cams will also cause clearance problems. I hope you're handy with a die grinder and have the air supply to run it for awhile.
After clearancing your crank, assemble your rods/pistons without the rings and trial fit for rod clearance. I found that my #1 counterweight bumped the bottom of the piston! Grinding to the counterweight was minimal enough not to require rebalancing,as small as the tip of your little finger, but a show-stopper none the less.
Repeat this clearance checking with the cam too. Beware certain Comp Cams that are had for a steal, there was an old batch a dozen years ago that weren't ground right (lobes) and will go "flat" in no time at all.
Go slow, don't cut corners and you'll have a very nice reliable motor.
Old 10-16-2013, 07:23 PM
63mako
63mako's Avatar
St. Jude Donor '08-'09
You can go cast or forged, internally balanced or externally balanced. A bare bones externally balanced, cast crank, hyper piston bottom end kit can be had for about $600. An internally balanced, forged bottom end with Callies compstar crank and rods and Mahle low expansion forged pistons will run about $1800-$2000. Top of the line forged crank with oliver rods and custom forged pistons is $4000 and up.
Old 10-17-2013, 09:38 AM
MSGT-R
MSGT-R's Avatar
..and if it's just a daily driver - not a track car - you're wasting your money on exotic parts. If it's never going over the stock redline, cast parts are fine. The rest is just bragging rights.
Old 10-17-2013, 09:44 AM
StraubTech
StraubTech's Avatar
What is your power number you want? 375 to 400HP can be with achieved with a 350 to 360CID engine.
Old 10-17-2013, 09:49 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Guys have been turning down cranks and using stock rods for decades before the real good stuff came out.
Ill never use the capability of my h beams.
Old 10-17-2013, 09:52 AM
MSGT-R
MSGT-R's Avatar
H-beams look really pretty sitting on the cart, but Carillo rods will cost you almost $100 per, times 8.. the ca-ching adds up pretty quickly!
Old 10-17-2013, 10:58 AM
CheezMoe
CheezMoe's Avatar
There is some interesting reading in these super chevy pages. check out items 3 lots of good info on building a 383 on a budget with details on clearencing etc. Section 4 also contains good insight!
http://www.superchevy.com/technical/...0_engine_tips/
Old 10-17-2013, 11:26 AM
MSGT-R
MSGT-R's Avatar
Good reading and lots of photos for the first timer:
Old 10-17-2013, 12:56 PM
scottyp99
scottyp99's Avatar
If you're new to thee 383 thing, this article is some great reading:
http://www.carcraft.com/techarticles...l_block_chevy/
Scott
To 383 stroker questions
Quick Reply: 383 stroker questions
