Website listing all Chevy suffix codes (Corvette, passenger, etc.)
Old 07-06-2002, 08:03 PM
hudman
hudman's Avatar
Default Website listing all Chevy suffix codes (Corvette, passenger, etc.)
Can someone on the forum provide me with a link that lists all of the suffix codes for Chevy engines? I have a casting book, and a Corvette book that has the suffix codes for Corvette motors. However, I do not have the suffix codes for non Corvette motors.
I have another thread running discussing my block. I am working another angle now to see if maybe there is an overlap of suffix codes. In other words, is the suffix code I am looking up in my Corvette book the same as the suffix code for '67 Impala meaning that I have an Impala motor instead of a Corvette motor. Just trying to run down all angles.
Please help. Thanks
Old 07-06-2002, 08:06 PM
theanswriz42
theanswriz42's Avatar
Cruise-In 8 & 10 Veteran
St. Jude Donor '08, '15
Default Re: Website listing all Chevy suffix codes (hudman)
Do you mean these?
1963-64 327 CID
Manual TRransmission RC
Manual Transmission and High performance RD
Special High Performance RE
Manual Transmission/Fuel Injection RF
Powerglide SC
Powerglide and High Performance SD
1964 327 CID
Manual Transmission and A/C RP
Manual Transmission, Special High Performance A/C RQ
Manual Transmission w/Transistor Ignition RT
Fuel Injection and Transistor Ignition RX
Fuel Injection, Transistor Ignition, A/C RU
Powerglide and A/C SK
Powerglide, High Performance, A/C SL
1965 327 CID
Manual Transmission HE
High Performance HF
Fuel Injection HG
Special High Perfomance HH
A/C HI
High Performance and A/C HJ
Special High Performance and A/C HK
Transistor Ignition HL
Transistor Ignition and A/C HM
Fuel Injection and Transistor Ignition HN
Powerglide HO
Powerglide and High Perfomance HP
Powerglide with A/C HQ
Powerglide, A/C and High Performance RH
Special High Performance with Hydraulic Lifters HT
Special High Performance, Hyd. Lifters, Transistor Ign. - HV
Special High Perf., A/C, Hyd. Lifters and Transistor Ign. - HW
1965 396 CID
Special High Performance IF
1966 327 CID
A.I.R. HH
A.I.R. and Powerglide HR
Special High Performance and A.I.R. HD
Powerglide HO
Special High Performance HT
Power steering, Spcial High Performance, A.I.R. HP
Special High Performance, A/C, A.I.R. KH
1966 427 CID
Special High Performance and Hydraulic lifters. IK
High Performance IL
A.I.R. IM
Special High Performance IP
Powerglide IQ
Powerglide and A.I.R. IR
1967 327 CID
A.I.R. HH
Powerglide HO
Power Steering, Special High Performance, A/C HP
1967 427 CID
4 Speed or Powerglide IL
Tri Power Carb JC
A.I.T., Special High Performance, Tri Power JE
Heavy Duty IT
Aluminum Heads IU
A.I.R. IM
A.I.R. and Tri Power JF
A.I.R. and Aluminum Heads JH
Powerglide IQ
Powerglide and Tri Power carb JD
A.I.R. and Powerglide IR
A.I.R., Tri Power, Powerglide JG
A.I.R., Tri Power, Special High Performance JA
1968 327 CID
Turbo Hydra-Matic HO
Power Steering and A/C HP
1968 427 CID
Special High Performance IL
High Performance and Tri-Power Carb IM
High Performance, Tri- Power, Turbo Hydra-Matic IO
Turbo Hydra-Matic IQ
Special High Performance, Tri-Power Carb IR
High Performance IT
Special High Performance, Aluminum Heads, Tri-Power Carbs-IU
* Note two "High performance" codes.
1969 350 CID
High Performance HW
High Performance and A/C HX
Manual Transmission - HY
Turbo Hydra-Matic HZ
1969 427 CID
High Performance, Turbo Hydra-Matic LL
High Performance LM
Tri-Power, High Performance, Turbo Hydra-Matic LN
Heavy Duty (L88) LO
Aluminum Heads LP
Tri-Power and High Performance LQ
Tri-Power and Special High Performance LR
Tri-Power, Special Hig Performance, Heavy Duty Clutch LU
Heavy Duty and Turbo Hydra-Matic LV
Tri-Power Carbs, Special High Performance and Turbo Hydra-Matic LX
1970 350 CID
Manual Transmission CTL
Turbo Hydra-Matic CTM
High Performance CTN
High Performance and A/C CTO
High Performance and Transistor Ignition CTP
High Performance, Transistor Ignition, A/C CTQ
Special High Performance CTR
Special High Performance and Transistor Ignition CTU
Special High Performance, Transistor Ignition, 4 speed CTV
High Performance 4 bbl Carb, Turbo Hydra-Matic CZN
High Performance, 4-bbl Carb, Transistor Ignition CRI
1970 454 CID
High Performance 4-bbl carb, Turbo Hydra-Matic CGW
High Performance and 4-bbl Carb CZU
Heavy Duty with 4-bbl Carb CZL
Heavy Duty with 4-bbl and Turbo Hydra-Matic CZN
High Performance, 4-bbl, Transistor Ignition. CRI
1971 350 CID
270 HP 4 Speed CJL
270 HP Turbo Hydra-Matic CGT
330 hp 4 Speed CGZ
330 hp Turbo Hydra-Matic CJK
330 hp 4 Speed - Heavy Duty CGY
1971 454 CID
365 hp Turbo Hydra-Matic CPJ
365 hp 4 Speed CPH
425 hp 4 Speed CPW
425 hp Turbo Hydra-Matic CPX
1972 350 CID
200 hp With Four Speed CKW
200 hp with 4 Speed, NOX control (California) CDH
200 hp with Turbo Hydra-Matic CKX
200 hp with Turbo Hydra-Matic and NOX control (California) CDJ
255 hp with 4 Speed CKY
255 hp with Turbo Hydra-Matic CKZ
255 hp with 4 Speed and A.I.R. CRT
255 hp with Turbo Hydra-Matic and A.I.R. CRS
1972 454 CID
270 hp with 4 Speed CPH
270 hp with Turbo Hydra-Matic CPJ
270 hp CSR, C
Old 07-06-2002, 08:23 PM
Robert N
Robert N's Avatar
Default Re: Website listing all Chevy suffix codes (theanswriz42)
See if this site helps:
http://users.cysource.com/dean/bigblock.htm
The site has the casting code you refered to as the 1967 425 hp 4 bolt main block.
[Modified by wireless guy, 5:41 PM 7/6/2002]
[Modified by wireless guy, 5:43 PM 7/6/2002]
Old 07-06-2002, 09:50 PM
SuperFast80
SuperFast80's Avatar
Default Re: Website listing all Chevy suffix codes (wireless guy)
This is a great one:
http://www.nastyz28.com/decode.html
This guy apparently used to work at Motion in its heydays. :cool:
To Website listing all Chevy suffix codes (Corvette, passenger, etc.)
Quick Reply: Website listing all Chevy suffix codes (Corvette, passenger, etc.)
