Trailing arm spindle support stud torque specs
Old 12-13-2013, 09:22 AM
GPGG70
GPGG70's Avatar
Default Trailing arm spindle support stud torque specs
This was a tuff one to search for last night.
Anyway can someone help me out with the torque specs for the support stud nuts. Much apperciated!!
Old 12-13-2013, 10:21 AM
pacecar620
pacecar620's Avatar
'78 Chevy service manual states: Drive spindle support to torque arm 30 ft/lbs. Strut rod to spindle support 75 ft/lbs (plus additional torque necessary to line up cotter pin hole). Happy to help. Hope this answers your question.
Old 12-13-2013, 12:27 PM
GPGG70
GPGG70's Avatar
Thanks pacecar620.
Sending these pictures to confirm that were on the same page. So these studs only require 30 lb/ft.
I thought it would be a bit more then that.
Thanks again.
Old 12-13-2013, 05:32 PM
Mooser
Mooser's Avatar
Received 3,138 Likes on 2,069 Posts
30 ft/lb
I found it in Van-Steel documents, also confirmed in a post from Gary R.
M
Old 12-13-2013, 07:13 PM
pacecar620
pacecar620's Avatar
Originally Posted by GPGG70
Thanks pacecar620.
Thanks again.
Yep, I agree, that doesn't sound like a whole lot, but that's what the book called for, and thank you Mooser for confirming that I was looking at the right thing. Now that big castle nut on the outboard end of the strut rod takes a healthy 75 ft/lbs and turn to the next slot in the nut for the cotter.
Old 12-13-2013, 07:24 PM
GPGG70
GPGG70's Avatar
Thanks, guys. I finished the passenger side T/A today. I'll hopfully get the second TA finished tomorrow.
I'm always on the van steel site looking at suspension goodies and I didnt see where they have a tech section or torque specs. However I might be on a different van steel site. Hint Hint!!
Thanks again.
Old 12-13-2013, 07:41 PM
Mooser
Mooser's Avatar
I tend to be overly careful with tightening stuff, mainly because I work a little here and then a little there. That and too many years working on military/aerospace stuff, "if it isn't documented, it didn't happen"
Van-Steel, There was a page in the middle (ok on page 9) of their cat. (looks like 59 in the new cat)
http://www.vansteel.com/2013webcatalog2.pdf
It's got some handy numbers to print and stick in your binder
M
Old 12-13-2013, 11:34 PM
GPGG70
GPGG70's Avatar
M
Thank you Mr. Mooser,
I've seen the PDF catalog many times and felt no reason to open it up cause I had access to the site. Lesson learned.
Thanks for the information.
To Trailing arm spindle support stud torque specs
Quick Reply: Trailing arm spindle support stud torque specs
