Cs144 alternator wiring modifications
I just purchased a new cs144 alternator to upgrade my stock one, as recommended by a few members here on the forum.
I searched the archives for what I need to do to beef up the stock wiring, and can't get a straight step by step answer from past postings. Which wires do I need to upgrade? Which wires do I need to add a fuse too? What size fuse do I need? Does anyone have a step by step guide for this upgrade? Thanks for all the help!
I am going to guess you installed a stereo system that requires a higher output alternator and the only wiring you will need to upgrade is the wiring to your new stereo system. The rest of the wiring of the car probably does need to be upgraded unless you attempt to connect this new system to anything but the battery.
I installed an AMP and SUB Woofer in my 1977 and I used a kit from Sousche to install the wiring and pulled all my stuff to the battery box in the cubby. I did not hook my amp into my wire harness and wired it all to my battery. There should be a lead from your head unit to turn the AMP on and off every time you turn the head unit on and these wires should be run on the opposite side of the tranny tunnel as the speaker wires so you do not get noise into the speakers.
Give me a minute....
I posted instructions here before....I'll go find them and post them again.
ok follow this thread....
http://forums.corvetteforum.com/c3-t...version-2.html
take note of how to measure the resistance in the circuit so you can figure out which adapter to make ( my post #27).
I installed dual electric fans and will be upgrading the stereo system in the future. I'm just not sure which wires on the old setup I need to upgrade.
Look at your wiring diagram.....
There should already be fusible links from the designated distribution center. On my 68 loads were distributed from the Horn Relay connections. The fusible links will work to save your wiring if you attempt to overload the circuits.
When I got my CS-144 I got it at junkyard since I was only buying to it to see if it fit, so I grabbed the output lead from it while I was there.
I'm guessing that it's about 6-gauge and it goes from the alternator to the horn relay "bus".
If you install fusible links to your loads (or fuses), then the main lead from the alternator should be the one you need to replace.
There is a person on here who will send you a wiring diagram if you ask him.....just do a search and email him for your year.
