Why my HORN is constantly on!?
Ok, so I have disasembled my stearing column for painting and after asembly my horn is constantly on. What the f**** is going on ?! It was perfect and now it constantly is beeping. How does it work and what mistake did I made during assembly?! Any ideas guys ?!
By the way, this is my Vetta:
and this is when I bought it:
Because you are horney?? sorry, could not resist.....
OK, on the fender well at the horn relay is a hard to spot green? wire on a plug coming into the relay from the bottom, that horn relay is a junction block for the wiring, which is obvious....so to pull down and unplug that wire, it eventually goes to the horn button on the steering column, and if you had that apart, it's easy to get that back wrong, and so ground that wire, and the relay closes and sounds the horn....
PM me if you have problems, as I may not see this thread again....
GENE
But I did not do anything with the wiring, so I think that I did not mixed the cables.
It is so dificult to build musce cars in europe, especially in Poland
its all the components under the horn ring, one of them is grounding out. i am betting you assembled the spring contact mechanism with out a bushing somewhere.
look at Ecklers part number 38135 and 30869
My horn is on when I try to put the stearing wheel and the spring touches the insides of the column. Looks like the spring is doing something wrong
tip 6 will give you the idea, remember the horn activates when a ground path is established so when ever te inner ring touches the lower ring it grounds itself activates the horn relay
http://corvettec3.ca/tips.htm
read this and down load Mr Sheas info. all the information you need is there
http://forums.corvetteforum.com/c3-t...ting-tips.html
The horn relay could be malfunctioning (contacts stuck together, inside) or something in the steering column is causing a ground connection to the horn signal line. (Normally, depressing the horn button will connect a contact that grounds that line.
Good advice...
Fred
ok so after reading all the articles, it looks like I am missing the no.1 from this diagram, cold "C" ring retainer. It should align the spring from stearing wheel so it touches only the proper posts, not everything around.
Does any body have any pictures how this part should look like or is it available in any web shop?
is this it?
http://www.ecklerscorvette.com/corve...1970-1989.html
also look at Ecklers part number 38135 and 30869
look at this guys post
http://corvettec3.ca/tips.htm[/QUOTE]
