Share Your C3 Upgraded Wheel/Tire Combo's
Old 10-19-2014, 06:56 AM
  #241
Jamess411
Jamess411's Avatar
On my last 68 I had the slotted mags like yours polished and they looked amazing. Just an idea
Old 10-19-2014, 12:29 PM
  #242
KJL
KJL's Avatar
Originally Posted by Griff2002
All four wheels are 18 x 8 with 4" backspace.
What tires are you running?
I am looking at getting the TT II's in a 18x9.5 but custom ordering a 4.5: BS and going with Nitto 285/40-18s on the rear and 18x8x4"bs on the front. I like the 285 because the of the diameter.
The rear 4.5 BS should fit OK but my main concern is the section or overall width of the rear tire is 11.4" and recommended rim size is 9.5-11.00. My concern is if I mount the tire on the narrower 9.5" rim, with the overall tire width still be 11.4"? If so, where will the widest part of the wheel be? This will determine if the tire will rub on the frame or not. I don't want to use a spacer because it will stick out of the wheel well to much. I really don't know how some folks got away with 5" to 5.25" back spacings.
Old 10-19-2014, 06:45 PM
  #243
BLUE1972
BLUE1972's Avatar
Received 1,129 Likes on 733 Posts
Originally Posted by Zoomin
That's for the whole set! Four wheels, 4 caps and 20 lug nuts.
They do look real good and for 4 that's not bad.
Old 10-22-2014, 09:18 AM
  #244
Pancho
Pancho's Avatar
Speaking of slotted mags -- American Racing has them in 17x8 and 17x9 that fit the C3's (needs ~ 0.125" spacers front and rear).
Still waiting for a chance to take better pictures, this is right after installation:
Old 10-22-2014, 10:52 AM
  #245
JimLentz
Support Corvetteforum!
JimLentz's Avatar
Which ones do you have on and what tire size(s)? I recently found out my 77 was ordered with the alloy wheels, but when I bought it just over a year ago it had the rally wheels. I would like to go this route and retain a similar look to the way the car must have looked from the factory.
Old 10-22-2014, 12:39 PM
  #246
Pancho
Pancho's Avatar
Google "ansen sprint VNA69" -- available from quite a few sources.
I went with 17x8 (P245/45R17) in front and 17x9 (P275/40R17) in back. that combination gives the same OD front and rear.
Fronts require 0.100" spacer (used 0.240") to clear the calipers, the rears required 0.200" spacer (used 0.240") to clear the park-brake cable bracket comfortably…
If I had it to do over again, I'd probably go with the 17x8's all around, and 255/45R17's... would fill the wheelwells a little better, 20/20 hindsight and all.
//Pancho
jim-81 (03-16-2022)
Old 10-27-2014, 09:41 PM
  #247
Beasley's 76
Beasley's 76's Avatar
Default 76 with Retro 18x9 255/45ZR18 x 4
I upgraded to the 18" at the same time I upgraded the power steering with the Borgeson unit. It drives and handles great.
CB-24 (05-21-2020)
Old 11-07-2014, 11:01 AM
  #248
jon53a
jon53a's Avatar
Default suspension upgrade
Originally Posted by Franks73
I would like to go with 17" Torque thruster rims on my 73. I added the Wilwood 6 piston front, and 4 piston rear calipers. A suspension upgrade kit from Ecklers, with rear sway bar. Steeroids rack and pinion. I think I would like to be able to rotate the wheels. Not sure what back space to specify, and tire size. Thanks for any experience you guys can share.
I buy most of my stuff through ECKLERS. I was wondering which suspension kit you bought and how do you like it now? I know that I need bushings all around, but while I'm in there........... any feed back is appreciated. Thanks
Old 11-07-2014, 01:31 PM
  #249
terrys6t8roadster
terrys6t8roadster's Avatar
Take a look at VP&B suspension kits. They have kits from almost stock to track car. Spreader bar, put high on your list. If you got lotsa dough the Vette suspension guro that took runner up at SEMA this year has some real trick suspension parts. T
Old 11-07-2014, 01:37 PM
  #250
7t9l82
7t9l82's Avatar
VB&P and the spreader bar.
Old 11-07-2014, 02:07 PM
  #251
groovyjay
groovyjay's Avatar
I'm really digging this set up, period correct look, with much better handling!
Old 11-07-2014, 02:08 PM
  #252
groovyjay
groovyjay's Avatar
Originally Posted by Thinpockets
17" AR Hopsters - 235-55 Sumitomo
No matter how long I stare at this, I can't find anything I don't love about it. Just perfect.
CB-24 (05-21-2020)
Old 11-07-2014, 02:42 PM
  #253
jon53a
jon53a's Avatar
Thank you. not much money, but things need taking care of. I need 2 bushings for rear align, cant see stopping there. where do I find VP&B? thanks again
Old 11-07-2014, 02:48 PM
  #254
jon53a
jon53a's Avatar
Thank you. that makes 2 of you. Very appreciative. this is a great place to learn!
Old 11-07-2014, 04:14 PM
  #255
BBrasse
1st Gear
BBrasse's Avatar
American Racing VN427, 18x9,5" rear 17x8 front
Old 11-07-2014, 09:59 PM
  #256
cagotzmann
cagotzmann's Avatar
I like your cobra wheel look. Those where my second choice for my 78. I went with the TeamIII Wheels. What offset did you get with them ?
Old 12-20-2014, 11:19 PM
  #257
mffi115
mffi115's Avatar
Default Work in progress
ARE TT-O's, 17x8, 4 1/2 backspace. Nitto 255/50/17
The other set: stock ralleys, BFG Radial TA, 255/60/15 rear, 245/60/15 front
To Share Your C3 Upgraded Wheel/Tire Combo's
Old 12-21-2014, 10:00 AM
  #258
TedH
TedH's Avatar
Any suspension, brake or frame mods to fit the wheels & tires?
I like the 18x8 with 4-4.5" backspacing TT II Anthracites for my C3. Just waiting until I sort out the rest of my car's issues (oil burner) before I upgrade the wheels/tires.
Old 12-21-2014, 10:03 AM
  #259
TedH
TedH's Avatar
Vette Brakes & Products is in St Pete, FL. I bought my front suspension, poly adjustable rear strut rods, and rebuilt power steering system from them:
http://www.vbandp.com/
Old 12-21-2014, 08:32 PM
  #260
Mod75
Mod75's Avatar
Finalist 2021 C3 of the Year - Modified
American Vectors with Hercules rubber, Front 255/60 Rear 275/60.
Quick Reply: Share Your C3 Upgraded Wheel/Tire Combo's
