need help identifying some wires around engine
if it helps with identification
the hood light bulb isn't connected to anything
the blower motor isnt getting power(per multimeter) but turns when wired direct to battery.
dome light wont come on when i open either door.
also horn doesn't work
hoping some of these wires will help me sort out those issues.
the black wire with one stripe on it, i couldent find it in my 77, may be the hood lamp bulb
the black wire on the pass side, goes to your blower motor, confirm this with multimeter
the 2 yellow or green wires on the pass side i also have disconnected, i think it was for the A/C
hope this helps
hope this helps
hope this helps
hope this helps
the the ground for the blower motor would make sense, but not sure where to put the plastic plug(green and black)
The green and black with the plastic plug is to activate the A/C compressor clutch. There should be somewhere to plug it in on your A/C compressor.
First picture. The black wire goes to the hood alarm switch that should be right behind your hand.
Second picture black wire goes to the AC bracket for ground. The hole above your hand that is empty is for that ground and a bracket that goes from that hole to the intake manifold just under the automatic choke. Since AC is not operational at this time neither needs to be hooked up t this time. I would say that the previous owner disconnect this stuff because the AC was not operational.
Third photo. It is hard to tell what the true colors were. If those 2 wire are able to stretch across the block easily the are for the AC idle switch ( both should be light green. If they are shorter the go down to the AC unit under the radiator over flow tank ( one is light green and one is dark green.
Forth picture. The large black and white wire I still do not have a handle on yet.
I hope this helps. None of these wires will help with the interior light. Look under the dash at the fuse box. It is not uncommon for people to pull the fuse if they are going to have the door open for along time ( usually one side of the fuse) or the fuse is blown?
The flat plug is for the A/C clutch. You do not currently have the compressor brace that goes to the side of the intake manifold. Double green wire on mine goes to the carb. linkage solenoid that increases the idle when the A/C is turned on. Will post more as I find them. mike...
Then to check that blue / white wire is to get a test lamp, hook one end to the unknown wire turn on the alarm and probe the other end to ground. It should light up and maybe sound the alarm. If the test lamp lights then turn off alarm and the lamp should go off. If that works mystery solved. I hope.
Frank's and '75's responses are correct when compared to my car. On the under hood light the black wire from to the light goes back to a short orange wire with a fuse link. The orange wire plugs into a larger red wire. The red wire is constantly hot as the light is switched on by a ball bearing in the socket when the hood is lifted. mike...
ok think i got a grasp on all that above.
still trying to figure out my blower motor
it turns then wired direct to battery, multimeter says no juice from connectors to blower motor.
i took the blower motor switch apart completely and rebuilt it( switch is good on all settings) taped multimeter to fuse and its good. wondering if there is a disconnect before the fuse or maybe several throughout the circuit?
maybe try bypassing the ground direct to battery?
well risked frostbit and bypassed ground to battery= did nothing
ran purple wire to battery= motor spins
frank you said something about a circuit breaker?
Let me look into it tomorrow. I will try to look at every component and see who is who. Including the breaker.
FYI where are you located?
Relay and resistor element on a '77. Press on! mike...
http://willcoxcorvette.com/instructi...arness_pdf.pdf
Mike FYI the link is a PDF for your wiring diagram.
A little diversion interior light again. There are a couple of things that are on the same fuse. Clock (if it works), cigar lighter. Do either of these work? I would not be surprised if the clock does not. But, the lighter should work?
The Circuit breaker is for the power windows.
OK I am off to look at the blower motor and stuff.
Last edited by Frank_Nesta; 01-08-2014 at 01:34 PM. Reason: Remove the bit about timer.
Interior lights
I don't know how new you are to Corvette's but remember everything has to be grounded. Each lamp has its own ground. And most electrical problem relate to a poor ground or someone remove it and not assuring it is put back correctly. OK enough of my soapbox.
