Latest AEM Meth Injection Kits! Good Price!
Supporting Vendor
The second generation (C2) Corvette, which introduced Sting Ray to the model, continued with fiberglass body panels, and overall, was smaller than the first generation. The C2 was later referred to as mid-years.[19] The car was designed by Larry Shinoda with major inspiration from a previous concept design called the "Q Corvette," which was created by Peter Brock and Chuck Pohlmann under the styling direction of Bill Mitchell
Ok, do I have to buy the complete kit?
Here's what I have, and what I would like to do.
I have a 290hp 350 with a 6-71 blower. I want to place a nitrous plate under each carb and inject the methanol thro those plates. Can I get everything I need to do this without having to buy the complete kit??
Supporting Vendor
Unless you already have a complete kit installed you will need to buy one along with a few extras. The kit comes with one injector nozzle which should be fine with 290 hp. But if want to run to small injector nozzles you will need to purchase another one along with the Tee fitting and appropriate hose to have one under each carb. A filter is also recommended. Someone else may want to chime in that has more experience with your type of setup.
Christian
Supporting Vendor
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9 Timing and Rear Main cover and seals.
The AlignIt tool gets the timing & rear main covers centered perfectly with the crank and installs the seal in seconds! Check out the videos.
Having the seal centered accurately with the crank minimizes the chance of seal leakage.
Timing Cover AlignIt Only $26.95
Rear Main AlignIt Only $37.95
Hub simulator only $23.95
Buy more than one of the AlignIt Tools and save!
Supporting Vendor
AEM’s Water/Methanol Injection Filter can filter particulates as small as 40 microns. It protects the working parts of the water/methanol system and the engine from particulates in the water/methanol mixture when installed in-line before the water/methanol pump, and can be used on virtually any water/methanol injection system using ¼” OD tubing.
Supporting Vendor
Both the power and ground wires for the pump are included in the harness which simplifies the wiring process and eliminates any chance of the pump accidentally activating from a short in the system.
Supporting Vendor
AEM’s engineers spent extensive time developing the controller’s flow control strategy for a more linear flow output delivery.
back in the day I built some supercharged boat engines with water injection and found on rebuilds the top ring groove showed excessive ring groove wear. I believe this was cause by the steam generated washed away the oil film on the top ring groove causing this wear.
Supporting Vendor
Hi PAmotorman,
With so many people using meth injection these days I would think if that was a problem we would know by now.
Back in the day I ran water injection using the windshield washer tank and pump.
Christian
Christian
Supporting Vendor
I picked up a 2015 Explorer Sport and I've been thinking of adding a meth kit after I get a tuner, 3 bar, thermostat, cai, downpipe, and Corsa catback. Then should be good for over 400 awhp.
I'm starting to like winter now.
#35
Supporting Vendor
We have Fangs, Alignit Tools,Big 3, Coolits,Optisparks Please check our Website http://www.saccitycorvette.com/index.html
