'72 with a '69 engine cast number
Old 01-29-2014, 03:50 PM
Rlockyer
6th Gear
Rlockyer's Avatar
Default '72 with a '69 engine cast number
I've got a bit of a mystery that I hope someone can give me some insight on.
My '72 200 HP base model coupe has engine cast number 3932386 which belongs to a '69 300 or 350 HP engine. To make matters more interesting, there is no engine code or partial VIN stamped on the engine pad. The previous owner told me that as far as he knew, the motor was original, but had been rebuilt.
Having the block decked would account for the missing stamp, but not the cast number. Is it possible the engine was swapped and I have a '69 300 HP base or a 350 HP L46? Maybe even a mythical '69 LT1?
Yeah, wishful thinking on that one. Anyone have any ideas how to get some answers?
Old 01-29-2014, 03:55 PM
blunblk68
blunblk68's Avatar
without the front pad stamp could have been out of a truck or impala???
Old 01-29-2014, 04:02 PM
Rlockyer
6th Gear
Rlockyer's Avatar
Not sure. The cast number is correct for a '69 Corvette.
Old 01-29-2014, 04:24 PM
blunblk68
blunblk68's Avatar
that casting number was not corvette specific and was used to build 302`s 327`s and 2 and 4 bolt main 350`s so it could have been out of any chevy made in 69 literaly!!!
Old 01-29-2014, 04:25 PM
blunblk68
blunblk68's Avatar
could possibly be the infamous dz 302!!??
i have the same exact block that is a 350 4 bolt main that came out of a 69 truck
Old 01-29-2014, 04:30 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
The 010 block would be correct for 72 Corvette smallblocks. Your engine was probably swapped.
Mashman
Mashman's Avatar
What's the cast date code? Won't tell you what it is, but it might exclude a number of possabilities.
Old 01-29-2014, 06:44 PM
Mike Ward
Mike Ward's Avatar
There's no examples I've seen of this casting number being produced or installed in anything later than early '69 production.
Old 01-29-2014, 07:49 PM
Rlockyer
6th Gear
Rlockyer's Avatar
I'm scratching my head for now. I'm going to take off the valve covers and see what the head no's are. I don't really care about the engine matching, but I sure would like to know what I have.
Old 01-29-2014, 08:37 PM
JimE
JimE's Avatar
What's the casting date on the block?
Old 01-29-2014, 10:20 PM
LeMans Pete
LeMans Pete's Avatar
St. Jude Donor '13-'14
Just pop the oil cap.
Old 01-30-2014, 08:34 AM
Rlockyer
6th Gear
Rlockyer's Avatar
The cast code is K-8-8. The last number may be 9. That would be Nov. 8, 1968 or 1969.
Old 01-30-2014, 08:36 AM
Rlockyer
6th Gear
Rlockyer's Avatar
Good idea. I'll check that today. Thanks!
To '72 with a '69 engine cast number
Quick Reply: '72 with a '69 engine cast number
