Water/Methanol injection for high compression engines?
Have seen the kits advertised but have never talked to anyone using them. So, does anyone have any experience with this and what are peoples thoughts. My engine is a small block gen 1 427 with 11½ - 1 compression.
Rob
Rob
Yes, 350 SB w/weiand 142 supercharger. Using snow performance kit. Running wiper fluid for injection. -40 has methanol in it. Works great, allows me to run pump gas with 9 lbs boost on a 8-1 comp engine.
Mind giving some specs on the motor? Is exactly what I am building. What cam are you running? Any advice or anything you would have done different?
Received 3,043 Likes
St. Jude Donor '05
ran a snow kit on my old 90 ZR-1 NA
Helped with pinging does make a difference
50/50 water-windshield wash fluid
Water injection I believe has been used in aviation for quite some time. I would just be very careful using Methanol. It is very toxic and absorbed right through the skin. Use care when handling it.
ibanez540, here is what I am running
SB 350 .030 over, Probe forged pistons, Edelbrock performer heads, 2.02/1.6 65cc chambers, Edelbrock performer cam 234/244 @.050 .488/.510 at valve, 112LSA, weiand 142 and matched intake, water/methanol injection, smallest pulley for 142 so 9lbs boost I believe. Compresison is 8.0 to 1. Cheapie deluxe HEI with hyper tech coil. Thats coming out and am adding a MSD 6al w/boost retard. Carburation is a 750cfm 4150.
yes it works.... go with something like snow performance or other very high pressure pump... works fantastic... just use blue washer fluid from any gas station or walmart.. its 40% meth... works great..
tap off your stock wiper resivour... works like a charm... look for the necessary triggers.. rpm, loading , boost, depending what you have..
vetteguy...do you have alum heads on that big 427? you should be ok with 91 with alum heads at 11:1...with a bit less timing...
if you don't drive the car a lot ,use high-octane gas .could you swap on lager chamber heads ?like a 75 cc AFR head .the right cam could kill enough dynamic compression to run 92 octane ,but it would hurt vacuum .
There is a very, very long history of rodders using water/water-alcohol injection on street-driven high compression engines. It's safe, it's cheap, and it works just as good as it did many years ago.
back when i didn't understand the the relationship to static and dynamic compression ratios i had a 355 motor in my vette that would rattle cruising down the highway at light throttle. I used Morroso 104 octane booster and then I went to a distilled water/methanol system
It used a small electric pump and attached to the engine vacuum as a regulator. The problem was it could go through its little 1/2 gallon in couple hundred miles and i always had to carry another gallon jug to fill it.
The fix was just to throw in a bigger cam and get rid of all the band aids
The car is definitely not a daily driver. Always run premium gas. I basically have no vacuum now. I believe we had only 6lbs when we checked it on the dyno. Built this motor to achieve 600+ hp. Not willing to change heads. The car will be run on the street and also the road race track. On the track I will use race Sunoco.
Oh I have dart heads on my motor
If you build a N/A motor and it has detonation problems caused by too small of a cam which caused overly high Dynamic Compression ratio. The most simple fix is to change the cam to a higher duration which will decrease the dynamic compression ratio.
yes, you can over cam a motor and ruin drivability, So you have to put some thought into DCR calculations. Changing out pistons or going to larger cc heads is much more expensive than a cam shaft.
I consider lowering timing, octane booster, water injection to be band aids because they are masking a problem
Who said anything about running a bigger cam than needed?
You can also have a cam ground with the intake lobe center retarded some to give you a later closing intake. This is one of the things the OEM's use to get away with high compression. FI and knock sensors make it easier for them though.
I like an engine that will rev and make power at or above 7000 rpm's, so longer duration and wider lobe separation fits my needs well. Of course you need heads that will support it too. My build would have come on harder in the mid range with a 108 LSA, but I would have more problems with detonation because usually you would also close the intake earlier with narrower LSA. I almost went 112 LSA when I ground my cam. 110 made for a good compromise.
Water/Meth injection has been around since WW2 in fighter planes, maybe longer. It works. It can become necessary on high boost applications. We used to use the boost itself to inject the water/meth. A line off the boost side of the turbo or blower to the top of a sealed container holding the water/meth. Then a line from the bottom of the container to a nozzle on the inlet pre-boost side on the turbo or blower. We would put an adjustable valve in the boost side line so as to have the injection kick in at the boost we wanted. Super simple system.
The best thing to do is plan the complete build out before you buy a single piece! I mean the entire car!
