how tight to make flexplate to torque converter bolts?
If you google it you'll find anywhere from 45-75 ft-lbs. My Service Manual doesn't really say, but has a chart with a "flywheel" line-item that lists 60-65 (depending on which v8 you have). I was trying for 65, but busted the first bolt I was torquing. I had it up to 40, but when baby stepping up to 65 it popped.
Maybe I should get a set of new bolts?
Maybe I should get a new torque wrench?
(it's a 350/TH400, btw, if it makes a difference)
While I have your attention ( ), loctite on these yes/no/other? red/blue?
Thanks.
Thanks.
Thanks.
Thanks.
No need! It broke....
the "flywheel" spec you found is for flywheel to crank bolts.
blue loctite
blue loctite
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,924 Likes
Thanks everybody - 3 new bolts all happily torqued to 35, and with a bit-o-blue loctite on each. Man, 35 doesn't feel very tight for those dudes, they basically got there just by tightening down enough to fight the compression turning the flexplate to get to the next bolt.
Good info about bolt diameter vs. torque rating; guess I never thought about it that way before. Always good to learn a bit everyday.
Lars, you literally had me LOL after reading this one. I'm sure there's a story behind that one, and probably not a happy story at that, but I'd sure like to see some pictures.
If your torque wrench actually stabilized at 35 ft-lbs as the flexplate was rotating, you may be OK. I like to use a large screwdriver or other tool to 'lock' the flexplate in place when torquing those bolts.
I used the blue locktite. Since it is impossible to get a socket on the bolt heads, I had to go by 'feel'. Since my nickname is 'Torquewrench Ted' (well deserved from past overdoing bolts), I have to be cautious and avoid the tendency to "...tightening it until it strips/twists and backing off a half-turn...".
I approximated it with closed end wrench at about 40lbs. Since the closed end wrench hurts the palm of my hand, I know when to stop
