wire from column please help
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
That is the wire(s) that operate your cruise control. It runs all the way to the turn signal lever.
Received 1,468 Likes
Cruise-In II Veteran
Former Vendor
Light green and blue??? I can't tell. But it appears as if there are two light green wires and a blue one.. if so, it's probably the neutral safety switch connector for the clutch pedal not used on AT cars.
i am switching to a manual transmission should i connect this to the pedals switch?what do i do about the other connection that used to be in the automatic shifter
Former Vendor
What do you have for a neutral safety switch? That would be my questions....
Let me look at a schematic tomorrow to make sure of the wires.. I'd rather be sure than sorry.
Willcox
Willcox
i have/had a neutral safety switch because my car was automatic. I have installed a 6 speed and noow i just jump the wires to start car. however i do not want to have the car like this just in case people try to start it without taking it off gear. thank you for everything
Former Vendor
We got ice last night and this morning ... I didn't have a chance to look at the schematic.
But..
Are the wires double light green to one terminal and blue?
What are you doing for back up lamps? On the automatic car, the neutral safety switch in the console was also the back up lamp switch.
But..
