Old School BBC 427 with new school 671HP...
I don't have all the details yet just a text that says 671HP at 6500 rpm. Chris this thing is amazing!!!
Pump gas 10 to 1 engine
Vic. Jr.
AFR305 Box stock heads
Straub Custom Solid Roller
Morel Ultra Pros
I promised them 630 to 640HP. I missed it again!
I will post the rest of the numbers when I get them.
Vic. Jr.
Morel Ultra Pros
Thats is kick **** power !! good job
want
Very early in my accounting classes I heard a good saying:
Figures can lie and liar's can figure
The point is: I know that you only made the cam and some engine builder built the motor and “Dynoed” something and then they relayed the info to you and then you posted the claimed results. I don’t fault you, every salesman has to be a good promoter.
Recently on here some guy was so jazzed about his “Dynoed” BBC that he posted the videos. The problem I saw was the motor on the dyno was not the same one on the next engine stand video. The dyno video had dyno uncapped headers, intake air bell, different manifold, carb, electric water pump……………………………………
So you are not even comparing Apples and Apples. Two different motors to get some bragging rights dyno sheet?
If I wanted to Mickey up a dyno run, I would also put an electric evacuation vacuum pump with about 20 inches of vacuum inside the engine and gain an instant 35 HP on these 600+ hp motors. Plus all the above items.
Then you tell the poor sap of an owner that his motor made 671 HP. When in reality he has 521 hp motor with all his pieces and parts with an exhaust system.
The easiest way to Mickey a dyno run is by inputting fraudulent weather data into the engine corrected HP and TQ numbers. Just add 2000 feet to the ADA from the weather computer numbers and the adjusted power readings go way high on the corrected power graphs
Not to be a nay-sayer, but i wouldn't think purring at 850 RPM would be an accurate description of an engine with 252/256 duration at .050" with a 107 LSA and 40 degrees of overlap. I would think the cam would be quite noticeable at idle.
Perhaps 850 rpm idle quality is due to bundles of ignition advance at idle and some good gas?
Before we start making doubting comments perhaps we should wait and see some more comprehensive dyno results from Chris's customer - I'm guessing Chris is simply passing on info relayed by his customer verbatim and will himself look to qualify the customers performance claims.
I had another shop call me about the "house car". "Chris saw what you did with the big inch NA LS engine, impressive. Need a camshaft. Here is the link:
http://www.yellowbullet.com/forum/sh...d.php?t=693506
The shop where the BBC 427 is had SBC 406 a year or so ago I recammed. It was a 7 year evolution of parts to get it where he was at the time. The cam company that had the stick in the car told the owner nothing was left in his 23 degree headed engine. The engine builder called and after running the numbers I said it had .2ths left. To the owners disbelief we gain an average of 35#/ft and 30HP and at the end of the season .3ths was had.
What I do is consistantly backed up at the track or on the water.
