Verification
Old 02-22-2014, 05:07 PM
anderson3754
anderson3754's Avatar
Default Verification
I'm hoping to put my cam in, and the timing chain on this Mon- Tue. As I'm thinking about this, when the cam sprocket dot is at 6 o'clock and the crank sprocket dot is at 12 o'clock as it would be for a normal chain install, pistons #1 and #6 are at TDC. But as I'm thinking this through #6 is at compression stroke correct???, or am I wrong on this, and #1 is at it's compression stroke.
Old 02-22-2014, 05:23 PM
TimAT
TimAT's Avatar
You are correct- dot-to-dot, both 1 and 6 are at TDC. #6 is at TDC on the compression stroke.
Only matters when you get ready to drop the distributor back in.
Old 02-22-2014, 05:33 PM
anderson3754
Thankyou for confirming that. In ref to the distributor yes, and if you wanted to button the motor up on #1 at TDC compression stroke or verify valve train geometry you would have to rotate it CW 360* to have #1 at TDC on compression as your base line to work off of.
Regards
To Verification
Quick Reply: Verification
