engine won't start
engine won't start
I cranked the engine after adjusting choke fast idle screw. Idle was way to high so I shut it down. Readjusted screw and tried to crank and nothing happened when I turned the ignition switch just a click somewhere in the engine compartment. I tapped on the starter thinking the prob was there and the interior lights came on but still nothing when I turned the ignition on. Car is a 71 454 4 speed a points dizzy, battery is good. Any info on what I can check and possibly how to do it? Not really up on electrical.
Check battery connections first , check ground wire to block .
checked connections as you suggested. Found a wire that had come loose from solenoid. Reconnected that. Still same prob. Interior lights came on but nothing when I turned ignition. Interior lights when off again.
Check my problem, "The size of my nut."
ftf,
I had a similar "no-start" problem yesterday and traced it to a break in a wire that comes out of the junction box screwed to the inner left fender. This wire was a single strand wire and about four inches long. It went into a fusible link and the other end went into the main wiring harness.
When broken, no "key-in-ignition" buzzer noise, no dash lights, no noise from starter in "start" position. When that wire was re-attached, all was good. Mine's a '74 L48, but yours may have a junction box in that position. I hope this helps.
Regards from Down Under.
aussiejohn
aussiejohn
First thing I'd do is rule out the starter. Jumper the solenoid with either a remote starter or use the country boy method...get a screwdriver and touch the large positive (+) connection on the solenoid to the small one located closest to the block. When you do this, the starter will either spin or your starter/solenoid is defective or a dead battery. If it spins over, the starter is good. Next, Chevrolet has always been big on using little fuseable links in the smaller wires with the 3/8" ring terminals that connect where the big red one does. If this link blows (opens), you cant see it. It will look fine. Tug on it a tad at the ring terminal back about 4 or 5 inches and see if it springs back when you tug it. If it does, it's open UNDER the external rubber sleeve. You just cant see it. You can prove this with a simple 12 volt test light. If you can jump the starter over and it works but it's dead at the key, and you've verified there are no blown fuseable links, you've narrowed it down to either a neutral safety switch, clutch safety switch or an ignition switch. Before doing all this, I'd probably take and make sure I don't have a safety switch either hung up or just not making a good connection. Manually run her through the gears a few times. Try and start her in neutral. If it's a standard, make sure you don't have a clutch safety switch hanging you up. Floor the clutch a few times. In closing, I'd bet you end up finding it to be something above. And since I'm an optimist, I'd bet it's a rather easy fix! Let us know!
Thanks everyone for your quick replies. Will get on these suggestions in a couple of day as it is around 10 pm where i'm at and monday am is coming soon. A thought could the disconnected wire on the solenoid fried the points or condenser to produce this problem?
Received 1,244 Likes
5 Stars !
First thing I'd do is rule out the starter. Jumper the solenoid with either a remote starter or use the country boy method...get a screwdriver and touch the large positive (+) connection on the solenoid to the small one located closest to the block. When you do this, the starter will either spin or your starter/solenoid is defective or a dead battery. If it spins over, the starter is good. Next, Chevrolet has always been big on using little fusible links in the smaller wires with the 3/8" ring terminals that connect where the big red one does. If this link blows (opens), you cant see it. It will look fine. Tug on it a tad at the ring terminal back about 4 or 5 inches and see if it springs back when you tug it. If it does, it's open UNDER the external rubber sleeve. You just cant see it. You can prove this with a simple 12 volt test light. If you can jump the starter over and it works but it's dead at the key, and you've verified there are no blown fusible links, you've narrowed it down to either a neutral safety switch, clutch safety switch or an ignition switch. Before doing all this, I'd probably take and make sure I don't have a safety switch either hung up or just not making a good connection. Manually run her through the gears a few times. Try and start her in neutral. If it's a standard, make sure you don't have a clutch safety switch hanging you up. Floor the clutch a few times. In closing, I'd bet you end up finding it to be something above. And since I'm an optimist, I'd bet it's a rather easy fix! Let us know!
ftf,
When broken, no "key-in-ignition" buzzer noise, no dash lights, no noise from starter in "start" position. When that wire was re-attached, all was good. Mine's a '74 L48, but yo urs may have a junction box in that position. I hope this helps.
aussiejohn
aussiejohn
Not sure what junction box you're talking about but your discription of symptoms is just like mine. Does it have a wire that goes to the alternator? Could you send a pic ?
Thx
ftf396
Well, just to let all know where I'm at on cranking, battery is good, cleaned ground cables, checked starter by jumping terminals , nothing. Then put voltage meter on solenoid just a trickle like 3/4 volt. Here's the fun part, bubba and his whole family had worked on my wiring, every thing going to the starter had been cut and spliced, I don't think there's a fusible link around. So I tried to clean up the wiring making sure connections were good and installed a correct 1108400, dated starter I've had for a year but still nothing. What should I check next the clutch safety neutral safety or switch and how?
Are you saying that you jumpered from the top terminal on the solenoid (where the big battery cable connects) to the small terminal closest to the block (where the purple wire connects) and the starter did not turn?
Time to stop and take a deep breath. Understand we'll try and help but you have to be very specific since its over the net. Is there good voltage from the battery to the starter. Check the starter ground Next operate the solenoid Just like the fbi follow the money we need to follow the voltage. I'm still leaning on starter and solenoid
