power door lock problem on my 79
My power door locks blow the fuse immediately when I press the button. I now have the door panel off, and have installed a spare switch without the door panel. Now the locks work perfectly. Obviously something is shorting out with the panel on, so my question is where should i begin my search? Which wire is energized when the lock button is pressed? The fuse does not blow with the door panel installed until I hit lock or unlock.
RPO AU3 Repair
