New cam shaft for a SBC 434
#41
First off with aluminum heads that have an efficient combustion chambers in them with that tight quench I have (.034"), it makes the engine less sensitive to detonation and it requires less overall ignition timing, 32 to 34 degrees total.
I had a very good cooling system with a 160 degree thermostat. I tuned the carb with a digital AFR gauge and a vacuum gauge. I still run a vacuum advance. It is adjustable for vacuum and I made a simple limiter to adjust how many degrees I allow it to come in. It ran great on good 93 octane out of a dedicated hose.
#42
1. Is high ignition = more early detonation ?
1a. If yes, then I will try to lock my MSD 8571 @8
2. Are you also telling me, that if I lower my engine temperature, that will help with my early detonation?
2 a. If yes, then I will buy a new thermostat.
Is there anything else that can help me wit my early detonation?
#43
Hi all,
Michael here in Denmark, has a 1968 Coupe. He would like to have a new cam shaft instead of the cam shaft he has in the engine.
He would like to have a TQ monster car from 0 to 5000 RPM
What cam shaft must he buy?
Car/Engine:
1968 Coupe
Transmission:TH700R4 (stall 2200)
Rear:3.70
Engine: 434 DART S.H.P./ BRODIX 10:1 COMPRESSION
BRODIX IK 180
COMP 12-433-8 HYD. ROLLER 520 / 540 - 236 / 242 2 .050-110 L/S
1.6 ROCKERS, EDELBROC 1411(750)
Car/Engine:
1968 Coupe
Rear:3.70
BRODIX IK 180
Michael just call me again regarding his engine.
He is happy with the power he has, the engine has more power, than he use for daily driving.
But he think his cam is too rough, he would like to have a street cam, and maybe with EFI within a year or so.
He is ok about loosing power by downsizing the cam.
We know that the heads are too small, and should have been bigger, but the budget is not for that right now. We know that AFR 220+ would be better.
What would be a good cam for him?
Would it be a good idea to go for 4/7 swap?
Would this cam work, also if EFI comes later??
http://www.compcams.com/Company/CC/c...?csid=175&sb=2
Thx.
#44
He already has a torque monster, I would put the money for a new cam into a new set of heads when he can afford it, if the engine is running good then leave it the way it is until he can afford new heads.
I don't think a cam change is going to make much difference if you lose HP you will lose TQ they go hand in hand.
What he needs is properly matched components and the heads are way too small. If he gets bigger heads both the TQ and HP will go up across the board and still be nice to drive in traffic.
Sorry probably not what you wanted to hear but a new cam is a crapshoot he could end up with something he doesn't like
#45
All this made Michael think and call me again, so now the plan is:
Step 1:
Bigger heads
New cam (for future EFI, 4/7 swap??)
Step 2: (end of next year)
One more ting the carb today is Holley 880 (04781c)
The car MUST be a street car NOT RACING, 450hp would be fine !!
So the first priority is street car !!, nice smooth driving.
What would you recommend?
Thx.
#46
New heads and the cam will be OK and the Carb is OK as long as it is tuned correctly. I would just slap on the new heads in 220cc range and you are looking at a killer engine with the HP and Tq Both going up across the board and it will be easy to drive on the street.
I run a solid roller cam 248/254 dur. with AFR 227 heads and you would not know how much power it has as the street manners are perfect. Until you hit the happy pedal then you know.
#48
Like this?
GRIND #: CS 3192 /3194 HR113.0
SPC INST 1:
SPC INST 2:
J. DIAM: STD INT EXH
VALVE ADJUSTMENT HYD HYD
GROSS VALVE LIFT .606 .622
DURATION @ .006
TAPPET LIFT 275 281
VALVE TIMING OPEN CLOSE
@ .050 INT 1- 45
EXH 48 2
SPECS FOR CAM INST. @ 113.0 CENTERLINE
INT EXH
DURATION @ .050 224.00 230.00
LOBE LIFT .379 .389
LOBE SEPARATION 113.0 FIRING ORDER 47S
ROCKER ARM RATIO 1.60 1.60
SPC INST 1:
SPC INST 2:
DURATION @ .006
TAPPET LIFT 275 281
@ .050 INT 1- 45
EXH 48 2
INT EXH
LOBE LIFT .379 .389
#50
Big heads, big cam, I don't see any lack of mid range TQ or HP in the engine I built and have been driving around for a few years now, I don't understand the small heads / small cam or big heads / small cam ideology
#51
If the heads flow more air quicker, you don't need to hold the valve open as long.
#52
The LS type engines have small duration cams and make big power, but they also make even more power with bigger cams but not as big as the Gen 1 small block 23deg head engines like. A big small block will tame a 240-250 dur. cam.
#53
I have pulled away camshaft duration and lift in many builds to come away with more power for the customer.
#54
Like this?
SPC INST 1:
SPC INST 2:
DURATION @ .006
TAPPET LIFT 275 281
@ .050 INT 1- 45
EXH 48 2
INT EXH
LOBE LIFT .379 .389
SPC INST 1:
SPC INST 2:
DURATION @ .006
TAPPET LIFT 275 281
@ .050 INT 1- 45
EXH 48 2
INT EXH
LOBE LIFT .379 .389
#56
One thing I thinking about, the engine was made by Ohio Crank (but specified by a dane !!)
When I look at OC home page, and find there 434 short block, then I says:
434 Small Block Chevy Short Block
•Motown block (requires small base circle cam)
•Ohio Crankshaft 4-inch crank
•JE Pistons
•6-inch H-beam rods
•Total seal rings
•Federal Mogul race bearings
•Billet caps add $300
If he order one of the above cams, then I assume he will have problems right???
•JE Pistons
•6-inch H-beam rods
•Total seal rings
#58
•JE Pistons
•6-inch H-beam rods
•Total seal rings
•JE Pistons
•6-inch H-beam rods
•Total seal rings
#59
You only want to hold the valve open as long as you half to to fill the given cyllinder displacement to a given rpm range. Lifting it or holding open longer achieves nothing but a peaky powerband and less power.
If you " pulled away camshaft duration and lift in many builds to come away with more power " then what you did was match components correctly which is of course what you want to do in any build.
What you are saying is with this particular engine he will make more power Tq. and HP across the board with a cam smaller than what he has in there now or any cam bigger than he has now ?
I will stick to what I know works and with AFR heads in the 220cc range he will make more power with a cam in the 240-250+ deg range over a cam in the 220-230 degree range and still be able to tool around town at 2000RPM. I would never even think of putting a small cam in that engine. A difference of opinions here that's all.
