Hei/Tach Question
Hei/Tach Question
I have a 73 Corvette. The owner before me installed a hei distributor with out the tach drive. The previous owner also installed a electronic tach out of a 75 or 76. I am having problems getting the tach working. I bought the car with it not working. I do believe the tach is ok though. I inspected the tach board and found no burn marks. When the key is turned to the on position the needle goes to 0 as it should. I tried hooking up an ignition analyzer to the tach side of the distributor to try and use it to read rpm but it also did not read any rpms. I have to admit i have never used this analyzer before. It was given to my grandpa years ago and this is the 1st time im using it. Before I start throwing money and parts to try and fix the problem I would rather figure out what the problem is first. The car runs just fine so I am obviously getting spark from the distributor. Is it possible that the distributor is working fine but not out putting a tach signal?
Any help is apreciated
Nick
Nick
To confirm you're getting a tach signal, (if the car runs you probably are), use a 12v test light. Ground the lead and touch the TACH terminal on the cap with the probe. The light should blink while cranking.
Is there a tach filter in the line between the distributor and the tach?
So i decided to just run to the auto parts store and pick up a cheap tach. It worked just as it should hooked up to the tach terminal on the distributor.
So i then hooked up the vette tach again. I supplied it 12v and the needle went to 0. While the cars running the needle moved below 0 to one point but did not change with rpms when i gave it throttle. Just stayed in one spot below 0. Key off and the needle returned to 0.
So do you guys think i need a whole tach or should i try a circuit board?
Nick
Nick
Do you have the dash out? I to take mine out 2 or 3 times during a similar conversion. If it is out, it would be easier to check the signal wire for continuity. It sounds like you have power and ground so checking the signal wire and/or running a known good bypass wire might be my next move.
So i decided to just run to the auto parts store and pick up a cheap tach. It worked just as it should hooked up to the tach terminal on the distributor. Oh No! Not on a C3!
Nick
Nick
