Do they make short spark plugs for people with headers?
The title kind of says it all. I put these headers on after my plugs, and am thinking it will be tight enough just to get the plugs out, I'm thinking shorter plugs will make my life quite a bit easier. If so what do you guys use?
Miles
Miles
They do make "header plugs" that are available from most of the big stores. The 'vettes still use a standard plug so as long as you get the same heat range of plug, you should be ok. Here's an example:
http://www.summitracing.com/search/d...spark-plug/yes
Received 3,043 Likes
St. Jude Donor '05
autolite also
I'm running headers with the stock plug wire routing and have no problems ay all with ACDelco plugs
I just picked my vette up about a month ago and the plugs that are in now are Bosch platinum HRX something and are definitely shorter than AC or Champion plugs. I cross referenced them online and they were for 5.7 SBC and seem to work fine.
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Most plug sockets hav a 3/4 hex made on the end for the drive. If you select a socket with a deep inner hex, so there is enough room, cut the plug end of the socket off. A cut-off wheel on a grinder works fine. Once on the plug, use a 3/4 in. wrench to loosen or tighten the socket.
