1973 vette door panel removal
I can't keep you from messing it up, but the procedure is quite simple. Remove the clips holding the lock **** and the window crank if not power windows. Remove the 2 hidden screws holding the door pull on. Remove 2 screws from the top outside edges. Remove the bottom screws in the clips on the door edges.
Pull away from door and push it up to free it. If power windows, unhook wiring harness and your are free.
