'78 dash lights update
Well the dash lights still don't work, but I'm going to replace the light switch to see if it's the problem - I think it is from all the test I've run.
BUT!!
The courtesy lights problem I WAS also having ( stayed on ) well I think I must have bought a female vette - LOL, because after removing the time delay module and jumping the white wires, I then pushed in the door jamb swithch in and the lights went out!!
So I thought I had cured the problem - wrong! I put everything back together, went to the driver seat shut the door, reattach the power at the battery and guess what the courtesy lights came on with both doors shut!! Now I'm P@#$ . Well now I go back around sit in the passenger seat pull out the grove box crap again, double check the jump wire, reattach power to the battery - lights come on - I push on the door jamb switch and the lights go out as they should. Well I shut the door and WTF the lights stay on?!?! BAM the light bulb in my head lights up - you guessed it the door jamb switch is good but adjusted in such a way the plunger doesn't break the ground when the door shuts! So I adjusted the F*&^#$ thing so it would work correctly, and they put everything back together including the time delay module and ALL IS GOOD!! So guys this is another gem to consider if you're having this problem.
Another note the 2 door switches are not the same - are there different versions?
BUT!!
Lol... And all my interior light bulbs are removed for this very reason! Glad I read this! Will check the door jamb push switch adjustment FIRST... Thanks for posting!
Boy was I surprised and relieved. Now I have to replace the highlight switch and the seals on the right headlight actuator (waiting on the mailman), I hope I luck out with these too. LOL!
My PO was NOT his own mechanic... So, after dropping $13k on the car after buying it, never drove it... 253 miles in 2 years... Decided he was better off with a 2012 vette... Wanted to put a blower on that... So sold me the 1981 for $8k with all it's little 'issues'... Just enough money to pay a shop to add his blower to the new vette.
Aside from the rebuilt th350 he had put in failing at 2500 miles, all the 'issues' I've fixed have been crazy simple... To me anyways...
Best of luck hunting down your wiring issue to the dash lights... We all know how cramped it is to access those wires, and the miles of wires these cars seem to have... I'm half tempted to reside all my interior lighting with LED strip lights... I've got lots left over from other hobby adventures and know where I can pick up 5 meter strips of 12v LEDs for less than $7... Any color I want... Been using them on my large nitro Rc Helis for years to turn them into nightships... Wouldn't mind a nice blue interior lights with white in other critical areas... Project for another day...
