1982 Upper spare wheel tub bolts?
Hi, my vette did not come with a spare wheel or spare wheel carrier. I now have one but it doesn't have the two bolts that go through the upper tub into the cross member below the fuel tank.
Anyone know what size these are or if they are a nut and bolt arrangement?
Thanks!
Thanks!
They are special bolts with large ends or some have hooks, depends on which year. The corvette parts folks should have them.
Received 2,878 Likes
Hi rh,
I think you're asking about the bolts that mount the carrier lid to the frame. There's a nut welded into the crossmember for the bolt.
Hex head 5/16"x18 x 9/16" long.
With a flat washer and split lock washer.
Regards,
Alan
Regards,
Alan
The bolts that hold the top cover to the frame are 5/16-18 x 1/2" and they have a small, flat 'fender washer' under them. They are torqued to 6-8 ft-lbs (72-96 in-lbs).
