Harmonic damper help help 911
Okay car is or was a 350/300 bored 30 over with a mild cam(do not know lift or duration. I purchased a new damper and I ordered for a 350/300. The left is what was on the car the right is new one.
The reason for new was because the one on the left has a speedy seal (never heard of that ) Thinking new would be better. The larger goes to a 350/350 hi perf. Thought maybe because of the 30 over and cam that someone went with a HP damper. Boy am I confused and wonder if damper on left is ok to use. ANYONE PLEASE HELP ME
R
R
The sleeve on the old balancer is for repairing any scoring to prevent leaking from the front cover seal. If it is not leaking it is OK. The balancers are two piece with a rubber bond in the center. If the rubber is not in good shape, the outer ring could move or separate --- otherwise not much to go wrong.
R
R
Steve
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Either one will work as long as they both are for a 350 engine.
On the original one, if the outer ring has slipped, it will throw the balance off, and will not time with the marks.
Going to the smaller one would require you to buy the bolt on timing tab to use the smaller one.
You need to use the balancer that matches the timing cover. There are 6 inch and an 8 inch balancers so the cover needs to accommodate the balancer it was built for. Don't use a six inch balancer if your cover is for an eight inch one. The distance from the crank centerline to the timing tab should be slightly more than half the balancer diameter.
According to David Vizard up to 6000 rpm your best damper for power and valve train control is the heaviest one available.
Use the one on the left.
Location: Las Vegas - Just stop perpetuating myths please.
For any '69 & later 350 dampner i get a 6.75" dampner with the timing mark 10 degrees before the crank keyway and has part #6272221 - $50. Also new part #12551537 - $75.
While all the Hi Perf 350" '70-'74 had 8" dampner with the timing mark 10 degrees before the crank keyway and has part number #6272224 - used on ebay. This is verified in my Chevy Power Book and would be the first choice but no longer available.
Also verified in my Chev Pwr Bk is the Heavy Duty off road 8" dampner with timing mark 10 degrees before crank keyway and has part #364709 - copied by professional products $75. This was the better product when built by GM. PPs ???
Dont use the #6272225 which is external balanced for the 400" blocks.
Make sure your timing mark is 10* before the crank keyway (2* is the wrong location unless u have a '68 or earlier).
Hope this helps,
cardo0
Hope this helps,
cardo0
TheCorvetteBen
'77s all had 350 engines. The base engine (L48) probably had a cast crank, and the high performance (L82) was supplied with a forged crank.
If you can ever look at the parting line on the crank, a cast crank has a very thin parting line, maybe 1/16", where the edges of the mold were.
A forged crank has a much thicker parting line, perhaps 1/4" wide, sometimes with grinding marks on it.
For a street engine at typical RPM ranges, a cast crank is perfectly adequate.
