what camshaft cor my L-81
I just bought a set of ZZ4 heads off of a forum member for my L-81. I'm thinking I might as well change the cam while I'm in there. So figuring I have the stock bottom end with dished pistons, 58cc chambers and a .028 head gasket, what would be a good cam. I need good vacuum since I'm still using the e4me carb.
A roller cam isn't in the budget just because I don't want to spend that much on this engine.
I'm using the stock aluminum intake, 1 5/8" long tube headers and side exhaust.
What I want: Torque
I'm thinking the comp 262HE or summit 1103 would work.
Any suggestions?
What I want: Torque
Any suggestions?
Almost forgot, Richmond 5 speed with 3.28 first and 2.87 rear gears
What I want: Torque
Any suggestions?
What I want: Torque
Any suggestions?
I'll post some cam specs tomorrow when I'm back on my computer (on my phone now)
I have a heated o2 sensor in the left collector. How do you like the cam? What heads are you using
I vote for lunati voodoo 262 cam....when I compared the comp cam to it the lunati had a slight performance advantage and Harold (the guy who designed both this and supposedly the comp 262 ) stated it was a newer and improved design even over the comp 262xe which was much better than the old he.
I would not go thumpr, bad vacuum and terrible gas mileage for lower performance compared to almost all the other comparable grinds.... it does sound good though and works OK... just not great.
Thumper will not work with the CCC for sure, so that's out.
I read in a few places the xe cams had trouble with the lobes wiping out becuase of how aggressive are, it would be nice to go with a newer grind like that or the lunati though
1) have you ran a compression test?
2) what rear gear are you running?
3) if you do go forward with your project, do the math and get your compression up around 9.5 / 10 to 1.
Good luck on your project. Blue
I ran the xe 262 h in my l48 with edelbrock aluminum heads and a wieand action plus worked pretty good, made 260 rwhp and didn't wipe a lobe. As others have stated the lunatic might be a better grind. Three things though:
My bad I thought the zz4 heads were aluminum. In that case keep the compression around 9 to 1. Don't count on gms 9 to 1.
They are aluminum
I tried a Lunati Voodoo cam...twice. Flattened the lobes at break in. My mechanic, who has built over 10,000 motors, said he had never seen anything like it. Unless Lunati has really improved their cams I would go elsewhere. He was a big advocate of the Crane Saturday Night Special. Good luck. Don't forget to read the threads on what to do and what not to do when installing a flat tappet cam ( if that is what you end up installing). They are extremely helpful.
that voodoo looks good except for marz saying he wiped out two of them on break in.
summit has it for a great price with lifters also.
i'll do a compression test soon , but I dont expect to see anything bad when I do. My car runs great right now, no issues, fires right up, never misfires, idles at 500 rpm without stalling. this is actually the best running carbed engine I've ever owned. I hate to tear it apart but I won't be happy until I get better heads and a cam in there.
If i used the compression calculator correctly, I should be at 9.5:1 with the heads and a 0.028 head gasket
If you are at 9.o c.r. or so an Isky 264 mega cam would build good low speed cylinder pressure with its 108 lsa and still idle smoothly enough for your ccc qjet. I had a 76 l82 and used the 264 mega cam and the idle was pretty mild but throaty. I had a 85 trans am with a 5 speed and replaced the 305 with a 350 9.0 crate motor that had the 350 hp cam and I used the stock ccc qjet with no problems. I ran a 305 firebird with the stock ccc qjet and a comp 252 206-206 110 lsa cam and it had a smooth idle. I think the ccc carbs are much more forgiving with bigger cams compared to tbi or tpi engines. Some of the older design cams are easier on the valve train too.
all the stories online about wiped cam lobes have me scared and now I'm looking at something like this:
http://www.summitracing.com/parts/hrs-cl113215-10
although I think this might work better with my CCC
http://www.summitracing.com/parts/hrs-cl110235-12
has anyone use this timing cover?
http://www.summitracing.com/parts/clo-9-221/overview/
Scott
