Stock Distributor - Melonite gear
Old 06-05-2014, 09:17 PM
Mooser
Mooser's Avatar
Received 3,138 Likes on 2,069 Posts
Default Stock Distributor - Melonite gear
And we're ground to a halt.....
Went to put my stock distributor together and found out that the MSD gear that comp-cams recommended for use with the new roller cam is for a .500 dia shaft. Stock shaft is .490 dia.
Anyone have a part number for a melonized, iron gear that has a .490 dia hole?
Old 06-05-2014, 10:12 PM
7t2vette
The ORIGINAL and bestest
Support Corvetteforum!
7t2vette's Avatar
Toronto Events Coordinator
This should work:
http://www.summitracing.com/int/part...6413/overview/
Old 06-05-2014, 10:25 PM
Mooser
Mooser's Avatar
Thanks, going to call GM tomorrow and see if I can get one through them or the local performance place
Not that it's exactly what's holding me up right now but it's at least one thing that can be dealt with.
M
Old 06-09-2014, 07:25 AM
Mooser
Mooser's Avatar
Received and installed, (only got the play down to .006+ but it'll have to do) so another small job checked off.
Thanks again for the heads up on the GM gear
M
Old 06-09-2014, 09:08 PM
7t2vette
7t2vette's Avatar
Awesome, glad to help.
To Stock Distributor - Melonite gear
Quick Reply: Stock Distributor - Melonite gear
