Excessive Pushrod Wear!?
Had the valve covers off to recheck lash and noticed where the pushrods seated with the rockers looked a little odd. Pulled the rocker off and this is what I found. Does this look a little worn for 500 miles!?!? I am wondering if this is why a few of them kept needing adjustments. Lash was set per comp's instructions with 1/2 turn more. Is this normal?
Received 3,043 Likes
St. Jude Donor '05
Why the extra half turn?
If those are the pushrodswith the pressed in ball on the end junk them all
This is the kit I bought:
http://www.summitracing.com/parts/cca-rp1412-16
Directions said to go 1/2 turn after 0 lash. Should I not? Is there a better kit I should get? I was looking at the 1.6 Scorpians...
Most of them look like this. I haven't looked at the other ends, but I would assume they look ok. They flowed oil so I dont think it was a lubrication issue. Could it be a bad batch?
?? REELAV8R, why was your comment on the spring size deleted?
When you put it together did you check the geometry of the rocker on the valve tip with an adjustable pushrod and checker springs to get proper pushrod length?
I did not check with an adjustable pushrod, but my neighbor who builds engines came over and took a look, He said they were the right size based on where they were touching the valve tip and where they ended their roll.
Cardo0 - I hear you, but pulling the intake is a bit drastic to do just yet, don't you think? I just drained the oil and ran a magnet through it and found nothing. I will put a magnet plug in the oil pan and see if it picks up anything. I'm also gonna do a compression check on the cylinders with the questionable lobes.
What prompted you to verify lash? Valve train noise?
What do the rocker push rod pockets look like?
Are the rockers positioned on the valve tips with the 2-piece guide plates on the AFRs?
Here is a photo of the rocker pocket:
Here is the lifter end:
...and here is the rocker end - looks a tad worn:
That is not Summit's fault - I don't think they should have to deal with it.
I sent an email to Comp and of course they are saying the rockers were probably too loose and that they, and I quote, "don't look compromised. Just a bit of cosmetic blemish at the tip." I am no expert by any means, but It looks like some of them are half the size that they should be.
Here is another photo of them all out on the passenger side - look at how deep the groove is on that rod from the guide plate - again...only 500 miles?? That is normal??
That is not Summit's fault - I don't think they should have to deal with Comp's negligence.
Here is another photo of them all out on the passenger side - look at the groove on the one from the guide plate - again...only 500 miles??
Also, I don't know what the part number on the pushrods is, but Comp does make pushrods which cannot be used with guideplates. Maybe you ended getting those by mistake.
Cosmetic blemish my ***. Those are junk, likely were when you bought them. I agree with the bad heat treating as likely cause. Replace them all. Always, always check for correct pushrod length with adjustable pushrod.
