Offset starter for 153T flywheel
Ive got a bit of an issue here... I have an SBC that only has the 168T offset bolt holes. Im using an LT1 T56 that uses a 153T flywheel. There is no straight across bolt pattern for a regular 153T starter. Anyone seen a starter that uses the 168T bolt pattern but is for a 153T flywheel?
That one says for a 168T flywheel. Ive been on a search for a starter for this application and cannot find it. I ordered a powermaster and will make a new piece to utilize the 153T location but use the 168T holes.
Thanks anyway
Thanks anyway
