1976 Radiator Removal
Old 06-11-2014, 07:32 PM
Brcmpbl
Brcmpbl's Avatar
Default 1976 Radiator Removal
Pulling the rad out of my 76 for repair. It is an L-82 4-speed, no AC.
I have the six rad support side bolts out, the two bottom support bolts loosened, and the top brackets off from the shroud and support. The two lower nuts are also off the shroud. Hoses off.
Of course, the rad still doesn't really want to budge from the support.
Did I miss anything?
Old 06-11-2014, 09:10 PM
hugie82
hugie82's Avatar
It's been awhile but that sounds like it. Did you take the fan off and get the shroud back away from the radiator? You might be getting the drain valve or lower hose part of the radiator hung up.
Old 06-11-2014, 09:24 PM
BBCorv70
BBCorv70's Avatar
Are you taking the entire support out or just the radiator?
I took the hood off of mine, removed the entire assembly as a unit, radiator, shroud and support. This made removal very easy. Once the support was out I removed the radiator. The radiator stuck to the seals on the left and right side of the support. It took some pulling to break it loose.
You can remove the radiator without removing the support though you will then need to deal with getting the shroud out of the way.
Old 06-11-2014, 10:13 PM
7t9l82
7t9l82's Avatar
it helps to have 2 people if your help will follow directions . the drivers side needs to come up first to get the lower hose fitting to clear everything .it is a bit heavy and awkward. i had help but gave up on the usefulness of that idea, came back and did it myself. good luck , take your time its a little tedious but you can do it.
Old 06-11-2014, 10:29 PM
Brcmpbl
Brcmpbl's Avatar
Hi guys.
I'm hoping to just take the rad out, and with the hood on, because I'm solo. I know it can be done, and I've got all the time.
The rad is definitely sticking to the seals on the left and right bottom brackets in the support (the two u-shaped brackets that hold the rad on the bottom - same as the ones on the top that I removed).
Not a lick of rust on the support, so I'm happy about that.
I don't have the fan off. It seems like if I can get the rad free of the sticky seals on the bottom, with the support tilted slightly forward and the shroud slightly back toward the engine, the rad might have enough room to come out. Maybe not. Maybe I should take the fan off?
Old 06-11-2014, 10:32 PM
Brcmpbl
Brcmpbl's Avatar
Also this car is an early 76, so it has the longer lower hose neck, which is on the passenger side.
Old 06-11-2014, 10:43 PM
7t9l82
7t9l82's Avatar
take the fan off, its only 4 bolts.
Old 06-12-2014, 10:32 AM
Brcmpbl
Brcmpbl's Avatar
When you say take the fan off, do you mean take the fan off with the clutch and all?
There's two sets of four bolts, one set bolts the clutch and fan together, the other bolts the works to the pulley.
Never have had a fan off.
Old 06-12-2014, 11:03 AM
Brcmpbl
Brcmpbl's Avatar
Got the fan off with the clutch.
Rad free of seals.
Thing still doesn't want to clear the shroud. It looks like I could pull the rad, support, and shroud as a unit with the hood on...might be my next try.
Old 06-12-2014, 11:16 AM
Peterbuilt
Peterbuilt's Avatar
Received 1,246 Likes on 966 Posts
Can you separate the shroud from the radiator and hang it on the water pump and then remove the radiator?
You may have to lift the drivers side of the radiator first.
Old 06-12-2014, 11:20 AM
BBCorv70
BBCorv70's Avatar
You may run into issues trying to tilt the support forward far enough to get the bottom of the shroud to clear the A-Frames.
I removed and replaced the hood on mine without help. It can be done, the hood isn't heavy. Just need to take your time, lay out some blankets to protect the edges.
Old 06-12-2014, 12:08 PM
Brcmpbl
Brcmpbl's Avatar
The hood can't come off, I'm just not set up for that where I am. Others have managed it with the hood on, I should be able to as well I hope.
I can get the rad clear of the shroud now enough to raise it slightly, and a lot on the driver side...but something is still hanging it up on the right side, doesn't want to move much, but looks clear.
Now when I read all those rad threads I can sympathize.
Old 06-12-2014, 02:29 PM
Peterbuilt
Peterbuilt's Avatar
Is it just stuck? Or
Could the top front "A" arm bolt be in the way?
The bottom hose neck might be in the way of that bolt.
Old 06-12-2014, 02:39 PM
Haggisbash
Haggisbash's Avatar
Originally Posted by Brcmpbl
Hi guys.
Hi Brcpmpbl, check that rad support very carefully on the inside, they rust from the inside out, if indeed you are blessed with a non rusty unit I would still suggest it would be a good idea to treat the inside with an aerosol can of anti rust solution. Fortunately there are sufficient bolt holes in the support to make this a straightforward task JMHO
Old 06-12-2014, 05:14 PM
Brcmpbl
Brcmpbl's Avatar
Well guys I relent. I'm going to have to get a couple of guys and I will try to pull the hood on the weekend.
I just can't get the lower hose neck to clear the front upper control arm bolt.
My goodness.
Old 06-12-2014, 05:23 PM
Peterbuilt
Peterbuilt's Avatar
Do you think it will clear if you take the bolt out?
Just keep track of the shims.
Old 06-12-2014, 05:55 PM
Brcmpbl
Brcmpbl's Avatar
Hi Peterbuilt. I could try that. The offender is the big bolt on the front of the arm (the head points toward the front of the car).
Old 06-12-2014, 06:27 PM
atp1234
atp1234's Avatar
I just did mine you have to remove the hood and you will not push the schroud up and get out. I tried that. once you get the hood off you can push forward the support bracket and get it out. Its much easier when you get all that stuff out of the way. good luck remember to mark the hood bolts so you can put them back in the same place and once you put the hood back on make sure you check the hood locks are lined up right or your next post will be how to get the hood open. what I did with mine is tied (tie down straps) to the hood levers so I could open the hood from the outside of the car in case it jammed
Old 06-12-2014, 07:26 PM
7t9l82
7t9l82's Avatar
it will come out you may need to manhandle it a bit. it is probably hung on the control arm, you may need to play with how high the driver side of the radiator is. it helps to have 2 people but I've done it without help (which was the ticket)
To 1976 Radiator Removal
Quick Reply: 1976 Radiator Removal
