Ok I'm having issues with my clutch change out. Everything is new fork, pilot etc. It won't shift with engine running without it running gears change fine. I've adjusted to within a inch of end of adj. rod. Clutch disc pres. plate TB all measured out almost the same distance.The clutch feels about right with pedal feel. TB is on fork right. Please help with some things to check.
What kind for clutch did you buy, Center Force? If so the pivot ball wasn't adjusted to the right height to give the proper throw or Travel. Ask me how I know.
If the engine was running I couldn't run through the gears, just like your problem, I could when the engine was off, also car would jump forward when trying to start, and I had the clutch pushed all the way in.
