Carburator size
Carburator size
Hi all. L48 with sportsmann 2 heads with 64cc chamber and 200 cc intake runners.
Summit 1104 cam, basic op.range 2000-5600 rpm.duration at 050 inch lift 224 intake/224exhaust. Lift 0465 int./0465 exh
Edelbrock eps intake.
Th400 with 2400 stall speed converter.
What caburator size will be the right one for this setup?
Thanks Peter
Thanks Peter
I believe carb cfm calculator programs are very close. I also believe in smaller cfm for drivablity over a small power loss at higher rpm.
It is amazing how much power race teams manage to get out motors with a two barrel carb or restricted to less than 600 cfm 4 barrel class cars make.
I always wanted to try a 650 DP on my 7500 rpm 383
Use a 750 Q-Jet and get the best of both worlds.
Holley 650 CFM 4175 vacuum secondary Qjet replacement-easy to fine tune, easy to rebuild, mine has been ultra reliable for 25 years now. Unless you have the OEM Qjet, I would stay away from after market ones and rebuilts-they can be very problematic, if not perfect. If you do have the OEM Qjet, send it to Lars for a rebuild , if necessary.
Looks like the EPS manifold is square bore. Qjet is spreadbore and may need an adapter that could raise the height beyond where you want it.
What carb do you have , what is/was on the motor when you got it?
I have an old 600 edelbrock on right now, but it's boiling and leaking fuel, so I was looking for a replacement.
Also, 200cc intake port heads and an EPS intake? That doesn't sound like a very good match, does it?
Scott
Unless you want to change your intake out for a spreadbore, I would toss the Edelbrock and get a new Holley
I can see your point,but at the same time I wanted underhood clearence, so maybee that was the best choise, I dont know.
I am in the same boat only I have a new weber/carter/edelbrock afb style 600cfm (actually 625) carb on mine now and its about to be started for the first time this week. everything I,ve read including desktop dyno says a 750cfm carb will give me about 6-7 more top end hp and torque but throttle response and part throttle behavior will suffer as well as mileage..
eventually I plan on looking for something like a 670 cfm avenger which should be a good compromise.
If you use a vacuum secondary carb of any brand flow rating will mean almost nothing. So they would be my first choice especially a Q jet type with the small primary and large secondary bores. The point is that the vacuum secondary's will only open as needed by the engine even if that means not opening all the way.
the Edelbrock site for that manifold shows up to 650 but the cam and heads seem to be at odds with the manifold
http://www.edelbrock.com/automotive/...ormer-sb.shtml
