Which performance hood is the best replacement
For my car. I want a new hood, but sure if the L-88 is the best. Have any of you guys installed the scoop that you can attatch to the stock hood? If so what do they require for installation?
Scott
If you're sure the L-88 hood is the best, you should get an L-88 hood. The separate hood scoops that you can graft onto your stock hood are difficult to do properly, and just don't look right, as you still have a section of the stock scoop or hood bulge that is not covered by the L-88 scoop.
Scott
Scott
Thanks Scott. Now I have to find a hood that will not cost me a FORTUNE. Any ideas?
Received 1,469 Likes
Cruise-In II Veteran
What are you calling a "performance" hood? What are you wanting the new hood to do for you?
If this is for your 74, I think the factory-style L-88 hood doesn't look quite right compared to a chrome bumper car with the short hood. That's just my opinion. However, if someone had me a super deal in one I wold probably run it.
That being said, unless you are actually adding a tall intake/carb/air cleaner setup, what is the purpose? Just for looks?
