std or heavy duty clutch fan
looking at which clutch fan to buy to suit 350 auto a/c p/s with the 7 bladed fan
the temps down my way in summer are around 104f-113f (40-45c) for a week or more at a time.
had a leaking std duty on the car, no part number found, but it never overheated
i have since rebuilt the engine, upped the compression etc.
i have worked out which physical size was on there from the Hayden chart.
found the part numbers for either std or heavy.
so with our hot weather which would you go for, replace with a std or go heavy duty?
since i have to order from the USA with $$ shipping, i want to buy one only once.
If it is a thermostatic clutch, ask what temp the clutch engages? The GM Base L-48 clutch engages at 180 degrees, the L-82 engages at 195 to make the engine run hotter for emissions. If you want the engine to run cooler, the lower temp thermostatic clutch would be better. I made the mistake of getting the L-82 clutch years ago instead of the L-48 one on my L-82. Just a heads up.
havent c'n any temps stated in the catalogs or on summit's website.
i think i'll just go heavy duty and be safe.
I kind of think "heavy duty" is a sales tactic . Use the rad you want, the thermostat you want and forget the heavy duty BS on the fan.
Received 1,244 Likes
Replace your thermal fan clutch with the same type that came off and how to tell standard from heavy duty:
http://www.haydenauto.com/featured%2...s/content.aspx
