cross-fire tool?
Old 07-07-2014, 06:48 PM
terry82
terry82's Avatar
Default cross-fire tool?
I seen this http://store.edelbrock.com/4025uni-s...rrelcarbs.aspx from edelbrock .I wonder if it could be used for the cross-fire tbs
Old 07-07-2014, 07:25 PM
Drawmain
Drawmain's Avatar
It looks like it fits one barrel carb tops. I'm not sure you could use it on the tb's, as there isn't enough room to fit the tool over the bore, and the tool would block the injectors fuel stream totally.
Old 07-07-2014, 08:33 PM
Wrecked82
Wrecked82's Avatar
I am far from an expert, but the balancing technique is to measure the vacuum over each TBI intake area via the provided connection. Balance both to the same inches of vacuum. Do not see how these measure AIRFLOW.
Old 07-07-2014, 08:53 PM
terry82
terry82's Avatar
because of the injectors some kind of a adapter on the throat of the tb would be needed.not sure of any thing till I get one of you rich guys to buy one.They showed it being used to set the the three carbs on a flat head .It gauges the amount of air that comes in thru the butter fly .If it could be made to work on a cross-fire it might make it easy to balance the tbs.i will be taking donations lol
Old 07-07-2014, 09:01 PM
terry82
terry82's Avatar
http://www.powernationtv.com/episode...tty-3-deuce-v8 this is the build .you will have to look to find it being broad cast
To cross-fire tool?
Quick Reply: cross-fire tool?
