Help!!!
Old 07-23-2014, 06:00 AM
Meangreen_217
Meangreen_217's Avatar
Default Help!!!
Does anyone know where to find offset power steering pulleys? I need one thats sets the power steering pulley back a little.
Old 07-23-2014, 09:23 AM
hugie82
hugie82's Avatar
There has to be a dozen different PS pulleys. You may want to look into a double pulley from a Pontiac.
The question is, why is you pulley off? Most PS brackets have spacers between the block and the bracket. Maybe you need to be shimmed out rather than in.
Old 07-23-2014, 04:27 PM
Meangreen_217
Idk y it's off, but it looks to b pushed out to far which means I can't shim it right? So I think I might have to start looking into different pulleys and if they r shorter maybe I can shim them?
Old 07-23-2014, 04:58 PM
DucatiDon
DucatiDon's Avatar
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
Pics are worth 10000 words......
You are more likley needing to shim all of your other pulleys out.
Old 07-24-2014, 08:23 AM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
supply pics or application detail motor/ size ? corvette ? C3.
your asking "does anyone know if a bigger tire will fit my Car ? "
if this is a C3 then you need to figure what is not lined up correctly.
wild guess water pump, or alternator was replaced, at some point in time,
this is the most likely culprit for your pulley misalignment.
Old 07-24-2014, 08:26 AM
AirborneSilva
AirborneSilva's Avatar
Does your alternator pulley line up correctly?
To Help!!!
Quick Reply: Help!!!
