Power Steering Pulley Question - CorvetteForum - Chevrolet Corvette Forum Discussion
Register FAQ Search Today's Posts Mark Forums Read Vendor Directory
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette
Old 07-24-2014, 11:54 AM   #1
Jartanyon
CF Senior Member
Jartanyon's Avatar
Default Power Steering Pulley Question
So after my rebuild, I installed my PS pulleys and noticed that the pulley on the pump is a little crooked compared to the main crank pulley. I also noticed that I can't put the PS bracket that connects to the engine mount bolt back on otherwise the alternator belt will rub against the PS pump. Without this bracket, I noticed I get a vibration at higher RPM from the PS belt. I got a pulley puller and pulled the PS pump pulley out slightly to compensate for the crookedness , but am at a loss for using the extra bracket without having it rub on the alternator belt. It worked just fine before the rebuild and nothing has really changed that would effect this. The other thought is I am using a longer alternator belt since my valve covers are a little taller and the alternator is all the way at the end of the bracket. Any ideas?
Jartanyon is offline   Reply With Quote
Old 07-24-2014, 06:14 PM   #2
commander_47
CF Senior Member
commander_47's Avatar
The power steering mount is pretty straightforward.
There is a part that attaches to the motor mount that sometimes gets installed wrong. This could cause your misalignment and vibration.
If the arm to the motor mount isn't connected, it will tend to wobble.
commander_47 is offline   Reply With Quote
Old 07-24-2014, 08:10 PM   #3
DUB
CF Senior Member
Your longer alternator belt is the problem. Because the alternator is laying out further...the alternator belt will rider and hit on the P/S pump. If you are using taller valve covers and need a longer belt so you can service the belt without either removing the alternator or the valve cover....which I have run into....GOOD LUCK!!! You have to figure it out.
As for the bracket that bolts to the front of the block and the front motor mount bolt. You need to get that in.
I have to 'tweak' them sometimes to get the pulley to line up.
ALSO...the two bottom P/S pump pivot/mounting bolts need to be tight AFTER you get the tension on the belt correct. If you leave them loose....the pump can pivot.
DUB
DUB is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Power Steering Pulley Question
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    New Borgeson Steering Unit - Possible Issue Jartanyon C3 Tech/Performance 3 06-14-2015 06:39 PM
    If it is too cold to work on my car outside... Jartanyon C3 Tech/Performance 3 01-06-2015 02:27 PM
    Woohoo! Finished My Fiero Seats! Jartanyon C3 General 27 01-01-2015 06:03 PM
    My Build Thread (Better late than never). PHOTO INTENSE Jartanyon C3 Tech/Performance 38 08-26-2014 12:32 PM
    Excessive Pushrod Wear!? Jartanyon C3 Tech/Performance 84 06-18-2014 02:59 PM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
