suggestions for a cold air intake
Engine in question has a crossram intake with stacks. The stacks are located above the intake runners at the height of my valve covers. I'm going to build an airbox over them. This box will have it's inlet facing forward, towards the radiator.
I would like to know some input on how to get the 2 sides to suck cold air and get a sufficiently big filter on those 2 pipes. Pipes would be 3.5" diameter each.
I've been breaking my head over how to get the pipes to go over the rad or something and then find a suitable space to put 2 cone filters or something up front (I also run a Canton Accusump of which the can is fitted right behing the bumper bracket in between the 2 headlights).
I have been pondering an aluminum radiator and electric fans to move the fan shroud out of the way, but looks like the space between the front crossmember and schroud of the electric fans would still be too small...and then I still need to fit a filter somewhere.
Input greatly appreciated.
Received 1,468 Likes
Cruise-In II Veteran
I mounted a Flexalite S-blade fan assy on the front of the radiator. Am using Sprectre 4" twin snorkel at the carb to dual cold air intakes that get their air pick up just below the front air dam/spoiler. My system doesnot work with a P/B booster, but you said you are building a custom air box. Just so you get an idea on how my system looks I could E-mail picts as I'm totally incompetent at posting picts here. Get a lot of compliments on my system, also no cooling system issues. T
I'm not using a round filter as I have a stack manifold with the 4 stacks on each bank just on the inside of the valve covers.
I can't remember who, but one member here has two 3" or 4" intake pipes running back to the area under the windshield and mounted two cone filters in the "rain gutter" on the other side of the firewall.
He had to put two holes in the firewall but it looks pretty sharp and is a good cold air source.
However that space is not generous on the one hand and on the other hand it contains the wiper mechanism. I live in a country where it rains ( a lot on accassions and usually when you least expect it)
http://forums.corvetteforum.com/c3-t...-77-and-3.html
I see, hm, not sure how you could ever fit a 4" pipe in there, but nonetheless he succeeded.
Anyway, I was thinking of a box with a flat panel air filter with the opening towards the cowl, that would fit into the bulge of the L88 hood. The airboxes would be connected to that box in the front.
So far this is what i've made. The box is almost complete. Top still needs to be made and the tube attached to the front.
I decided I'm going to cover the box in carbon fiber to make it look better
Almost finished item. A little rough around the edges still but this is the general idea.
Had to make some compromised with the intake tube entry. Hopefully it won't disturb things too much.
Location: Las Vegas - Just stop perpetuating myths please.
Wow! U really have some time and effort into those air boxes. Really some professional looking work too. This really gets my cranial idea section rolling.
Well rather than try to tell u what to do i will just say what i would do. The only real direction left for more room is up. Yes scoops. U all ready have the filters in the air boxes right? And with the front angle of the hood it (they) shouldnt have to be that hi/tall. Just get them at least 1/2" above hood surface for good air stream. And an easy trick here for rain abatement is place the scoop where the air makes an S turn into the box - anywhere in the box will do - and drill the rain drain holes into the rear of scoop such the dynamic air press forces water backward and out the drain. FYI dynamic ram press is only like 1/2psi @ 100mph so dont expect much for supercharging - just enough to over come loses in the flow path bends.
Yes this would take some type of seal to the hood. But u can buy the old pontiac GTO style ram air scoop from plenty of on the shelf vendors and in various sizes/heights/lengths.
Cool, hey thx for posting your engine.
I'm looking into tilting the radiator backward and have just enough room to pass the 3.5" diameter tubes over the radiator into the nose.
Anyway, I think I will put a layer of carbon fiber on them to make them look ok.
Wow! U can have a 500hp cross ram IR fuel injected motor under the hood but change nothing above the hood line? That bureaucracy is worse than california's.
