Hood Clearance List
Old 09-01-2014, 10:48 PM
  #41
Dodosmike
Dodosmike's Avatar
1 Year
2 Motor (SB or BB)
3 Hood (L-48 or L-82)
4 Carb
5 Intake
6 Air Cleaner
7 How does it fit? Works or I tried it and it Does not work[/QUOTE]
1978
SB 350
L82
Quick fuel 650ss
Edelbrock performer (2101?)
3" K&N
Tight fit. Without a drop base there is about 1/2" clearance. Rubs the hood insulation a bit. I'd like to put a drop base on it so I can use my little chrome wing nut and not need a 3/8 wrench to remove the nut each time.
Dodosmike
Old 09-02-2014, 08:20 PM
  #42
Vette-kid
Vette-kid's Avatar
I'd like to see some actual measurements for stock hoods. Would have to measure off the block somehow. Say from the top of the block near the oil pressure port, what is the measurement to the hood for a 78, etc?
Old 09-02-2014, 09:32 PM
  #43
Duane4238
Duane4238's Avatar
sb 350 base engine
stock small block hood
Holley double pumper 650cfm
Edelbrock Performer intake
Moroso dropped air cleaner (low profile)
This setup would not fit with the stock wing nut on top of air cleaner. Had to cut the stud down a little and use a hex nut instead of the wing nut. Fits fine this way.
Duane
Old 12-17-2014, 05:17 PM
  #44
gcusmano74
gcusmano74's Avatar
Originally Posted by resdoggie
1976
355
stock hood
Holley 4150 Street HP
Weiand Team G
14" x 4" open element 1 3/4" drop made by Allstar.
1/10" clearance or less
Wow. That is an air cleaner!
Old 12-17-2014, 06:46 PM
  #45
donyue
donyue's Avatar
2 - 427 Dart SHP SBC
3 - Stock L-82
4 - Quick Fuel SS750
5 - Weiand X-celerator with 1" spacer
6 - Moroso Low Profile 65910 - 14"X3" with 1" drop base
7 - Everything fits great with room to spare. I might look into Pauldana's custom air cleaner snorkel in the future in order to get cooler air to the engine. Cooler air equals more power
Old 12-18-2014, 02:51 AM
  #46
terrys6t8roadster
terrys6t8roadster's Avatar
Mocked up my engine upgrade for the 6t8. New AFR 195s, Victor JR, Vortec V1 with the air bonnet and guess what, the hood doesn't fit again. Only off by a 1/2" or so.
Mocked up the engine upgrade for the 6t8. New AFR 195s, Victor JR, Vortec V1 and air bonnet. Set the hood on, an it, well you guess it, it doesn't fit. Need to find a shorter bonnet, well it's only money and spring is coming and maybe that money tree I planted last year will bloom. T
Old 12-18-2014, 05:52 PM
  #47
havesometo
havesometo's Avatar
Old 07-16-2015, 10:51 AM
  #48
jkippin
Support Corvetteforum!
jkippin's Avatar
Bringing back an old thread....
1976 Corvette
SBC
Edelbrock Performer RPM intake
Carb is an Edelbrock 750
Air cleaner is a drop base Trans Dapt with a 2.5 filter
.500 spacer to clear the electronic choke
This fits under the stock hood
Old 07-17-2015, 01:15 AM
  #49
pauldana
pauldana's Avatar
1976 Corvette
SBC
if you run a drop base like that with a 2" filter, look inside, you have like a 1/2"-1" only gap where the air passes in the air filter.. you do not want to do that if you are looking for performance.
Old 07-17-2015, 10:02 PM
  #50
MN80Vette
MN80Vette's Avatar
GM Performance 350 HO
Stock L48 hood
FAST EZ EFI
Edelbrock RPM Air Gap with 1/2" spacer
C5-like "bat wing" ahead of the radiator, Vararam bridge through a modified radiator support, and a Spectre plenum
Works great and has 1/4"-1/2" of extra clearance.
Old 12-28-2018, 05:07 PM
  #51
C3 Stroker
C3 Stroker's Avatar
Small block
Ecklers 4" extra tall L88 Hood
ProSystems 1000 Carb (Holley 4150)
World Motown Intake (5.63" carb height)
AFCO 1¾ drop base air cleaner (actual measured drop) with 3½" element
Fits with about 1/8" wiggle room
Old 12-28-2018, 05:35 PM
  #52
jpattt24
jpattt24's Avatar
1971 L88 Hood Fitech Fuel Injection single plenum 6.5" tall shootout style intake 383 small block 14x2.5 standard drop base air cleaner Hood barely rubs on real hard acceleration. going to try a LT1
air cleaner to see if I can get some more clearance.
Old 12-29-2018, 05:07 PM
  #53
OldCarBum
OldCarBum's Avatar
Received 4,638 Likes on 2,908 Posts
Great info. Thanks.
Old 09-01-2020, 11:04 AM
  #54
Christopher Sandoval
1st Gear
Christopher Sandoval's Avatar
Default Cowl induction hood
Originally Posted by Jbster
1977
454
Stock hood
Edelbrock carb
Performer RPM Air Gap
Edelbrock 1" drop base w/ 3" air filter
Doesn't fit (I knew it wouldn't) Going to be adding hood scoop; probably stinger style. Need about 2 to 3 more inches of clearance.
hey guys I know this is a corvette forum but I just have a quick question on a new 97 model Chevy c1500 , I’m going old school putting a big cam and high rise intake with a 750 double pumper on a350 sbc will a cowl induction style hood clear it? Or would I need something custom??
Old 09-01-2020, 12:05 PM
  #55
ddsmith60
ddsmith60's Avatar
BB
Hood L-88
Edelbrock Pro Flo 4 EFI with a 4150 style intake manifold
1.625" drop base 3" element
Hood clearance is just about right with the drop base. I couldn't get away with less drop though. I have about 1/2 inch clearance between the air cleaner top and the hood at the shortest distance.
Old 09-01-2020, 01:20 PM
  #56
ykf7b0
ykf7b0's Avatar
Factory L-48 Hood
Late 90's Vortec Heads
Professional Products Cyclone Intake Manifold
Factory Air Cleaner
(Hood closes fine and I like the stock snorkel air cleaner getting fresh air from outside the engine compartment)
Old 09-01-2020, 04:19 PM
  #57
PeteZO6
PeteZO6's Avatar
Default Update On Drop Base Air Cleaner
I indicated below I’m running a stock drop base air cleaner. That’s not quite true. Look at the photo, notice the thin stainless tube running from the passenger side valve cover to the air cleaner base. The thick hose on the stock base interferes with the secondary accelerator pump - it’s a double pumper. I bought a new base, cut off the stock hose and fitting, then after fitting the stainless tube into the resulting hole, filled the gaps with RTV. It clears the secondary accelerator pump perfectly, the PCV system functions correctly.
BTW, those are C4 valve covers (and heads). I pried the C4 style crossed flag badge. and what do you know, the C3 badge fit perfectly.
Originally Posted by PeteZO6
1. 1969
2. SBC
3. Stock 1969 small block hood
4. Holley 4150 DP
5. Bow Tie LT1 style high rise
6. Stock drop base open element. 14"X3" element
7. Works fine. As I recall, about 3/4" clearance at closest point. Basically an LT1 setup w/o a carb insulator under a stock SBC hood.
Pete
Old 09-01-2020, 04:32 PM
  #58
lakerider57
lakerider57's Avatar
Stock hood
383 Stroker
QuickFuel 750 carb (4150)
1/2" carb spacers to get access to vacuum ports & heat isolation
2" drop base w/ 3" air filter
Does fit fine.
Quick Reply: Hood Clearance List
