Pictures and thoughts on qjet install/restore
Thanks Lars, I knew I must be missing something! My mechanic friend is grabbing an old carb tomorrow to steal the plate and the long mounting screws I am missing. The cost to send it out to you across the continent is prohibitively expensive, but I would certainly accept a picture of the proper one so can make sure we get the appropriate style.
I was able to get a bunch of different vacuum and brass fittings so I should be able to bend cut link and tee any lines I need to get the vacuum system up to at least running order.
Can I run both the Dizzy vacuum advance and the tranny line from the small manifold port beside the brake booster connection on the back of the carb? I found a 3/8" 90deg to put into the manifold and I'm going to run a second 3/8 line beside the brake line and add a few Tees to clean up all the rubber hosing coming from that corner.
The fuel line I will just keep a rubber jumper in for now. It was recommended to me to install an external in line filter as well as an extra layer of protection. Any thoughts?
Ah, i see the other bracket portion lars is talking about. That would.make the kickdown cable long enough! I hope we can find something that will work
Done!
Tight but it seems to work
Everything actually connected, I found the original cruise control stud installed on the old holley!
now I just need to figure out if there was originally an AC idle solenoid ( i think that's what that solenoid in the picture is) and if it was connected to this floating black wire with a green or blue stripe that used to reach that far
Location: Las Vegas - Just stop perpetuating myths please.
Awesome brainsoft. Thx for all the pix too. I learned a lot 'bout a fully equipped C3 with cruise, auto trans and AC.
I think there were 2 different solenoids for the qjet. One was an idle stop for the AC cars. Another was and anti-dieseling solenoid to stop engine run-on after shut down. I think the anti-dieseling solenoid was its function on C3 corvettes but Cadillacs and others it was used to bump up the idle for AC use.
Ill look at my chiltons when i get back home to correct wiring.
Well i didnt adjust the kickdown cable so the car ran like crap first time out. Fixed that and still idle like crap.
Turns out i had the dizzy in a tooth off and it was way over advanced, was running only with vac advance disconnected. Very lean and trying to over heat. Got that sorted out though.
Also had a big vacum leak due to a missing vacuum hose barb on the carb... at port "k". We lathed an aluminum plug and hammered it in there and things are running amazing now. Still a vac leak to track down and the dizzy to pull but it is all very happy.
It is almost like this carb was made for the car! Idles low, launches, pulls hard at any speed and purrs like a tiger. I didnt think i could fall in love with this car a second time but I was wrong!
Looking at the wiring diagram looks like the black wire blue stripe is for idle stop solenoid. More research...
