76 Elect Tach--needle sticks?
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Ron.. is it necessary.. In IMHO, no...
The function of the filter is to knock off the edge of the square signal before it hits the board chip. It will also prevent spikes from knocking out the board. But.. the chip (on both the original and repro boards) is capable of reading both squared and rounded signal so it's not necessary and there are plenty of people out there using it without a filter.
Spike insurance, maybe.. but a must.. no..
Willcox
Willcox
Thanks Wilcox! Great info!
Do you reommend owners replace the board if the dash is completely out if they had only a few issues? or do you chalk it up to bad/dirty connections?
BTW, are the tach needles for the 75-77 the same as 68-74?
(i have one from a 69 was thinking of using on my 76 elect)
Thanks!
Ron
Thanks!
Ron
Former Vendor
Thanks!
Ron
Thanks!
Ron
Corvette Left Hand Dash Pad Removal Made Easy 1968-1977
But.. for us it's a job we've done over and over and over.
For the average customer it's not that easy and pulling the tach back out is a real pita.... I would surely test the tach before installing it in the car new board or not, and it's very easy to do. With the tach in hand, run power and ground to it from the car and then run a jumper wire to the distributor for signal. You can then start the car and see if it's working. I'm in the shop right now and our guy that does this job say's the hardest part is going back together and keeping the bulbs plugged in. The main harness is huge behind that dash pad and he said it will in most cases knock a socket out going back in.
In todays world.. I would also take a picture with your cell phone of the back of the cluster because once you are putting the pad in place it's hard to remember which bulb goes where. The back of the metal gauge housings are all marked which color goes where.
AWESOME info Wilcox!!!
Lastly!...are the tach needles the same for 68-74 and 75-77?
(since the later did not have removable faces, wondering if they are the same needle)
thankS!!!
Ron
thankS!!!
Ron
Willcox
Willcox
Found one at Volvetts that has the brown wire and they have the connectors, both male and female to hook into the tach and tach wire on my '75. (Sorry Willcox, we talked about that.)
Ed
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
FWIW, I upgraded my original HEI with the MSD super HEI upgrade kit. It has a rev limiter. When you turn the ignition to the 'on' position, the tach needle will sweep to the rev limit value you set. I couldn't get this feature to work until I removed the tach filter. The tach works as it always has.
resdoggie! HOLY COW! YES. I am upgrading mine to HEI with MSD ready-to-run pro billet kit with the built in rev limiter!
That solves that...no tach filter.
thanks all!
thanks all!
