Tire Size 71 Big Block
For a 71 big block, with original (tired) suspension...what would be the best tire size?
Eventually going to rebuild suspension, but not yet.
I want a tire that will look good...fill the wheel wells....but not rub.
225/70/15 BF Goodrich T/A fit nicely,no rubbing,good availabilty,and reasonably priced.
Received 3,139 Likes
I ran a set of 245/60 all around but seemed a little short for the wheel well (at about 26-1/2", also the rears would rub on the e-brake clip if I wasn't careful (before I relocated them)
Tried 275/60 rear 235/70 front, fit no problem but on the stock rim the 275's pulled in so far compared to the 235 front that the white lettering was noticeably closer to the rim and made them look shorter than the front. Would probably look ok black wall out.
Settled with bfg 235/70 all around, no clearance problems, fills the wheel well at 28" with stock size rims and sitting up close to stock height
Mooser
Mooser
Since P255/60R15 tires were factory optional from model year '78 onward on C3s, why avoid that size? They fit, look good, and the cars respond well with tires that size. The diameter is right for the speedo to be reasonably accurate.
I've been running tires that size for decades on my '69 with no problems.
Pete
Pete
For my 69 BB, I went with BFG Radial T/A 245/60 15 all around on stock rims. Outside edge of tire lines up perfectly with the body, any larger and the tire will stick out. To get the rear ride height to spec with the smaller than stock diameter, I went with the adjustable 8" bolts.
Pete
Pete
All of this is also to be combined with the various worn out mounts, springs, bushings, etc. What fits on mine doesn't always fit on another 72.
M
