Gas tank filler drain hose
Finalist 2021 C3 of the Year - Modified
Going to replace the hose that drains off water from around the gas filler neck on my 75. Have the new drain hose and checked the Aim and it shows one bolt holding the line in place
What keeps the top on the hose in the rubber catchall tray around the filler neck? Just a force fit? don't see any other clamps etc. Tank is still in the car so working around it.
The old hose drains somewhat but not to my liking, used air comp to blow the line out and ran a small wire down it but still drains very slow.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
A nipple.. The nipple went in the overflow boot from the top side... then into the hose holding it in place.
The picture in some Assembly manuals show this wrong.
Willcox
http://willcoxcorvette.com/product_i...oducts_id=3700
Willcox
Former Vendor
If you have the old hose attached to the boot, I'd bet you still have the old nipple.
Willcox
Willcox
You are correct, just looked this afternoon and can see it.
Considering its only 40 years old i probably will be ordering one from you when i break the old one while removing it
Former Vendor
Mod.. I've used them over and over and over again.. My guess is it's okay.. But check it before you order.. These cars are expensive enough without spending money on something you don't need. If you do... I've got them..
Willcox
Willcox
How many vendors would give you advice as this on a potential customer sale?
Donnie
And if you are replacing this hose, don't forget that there is a long spring inside the hose that the vendors do not include with a replacement hose.
The spring gives the hose some formability so it doesn't flop around.
I thought retirement meant I could do whatever i wanted-to do, guess i was was wrong ...
My wife just asked, isn't that the place where you order your parts from?
Yes, i say.. Willcox..
Last order, they said just get it in town locally, the heater core.. And save on the postage..
OK, just send the heater core air /gasket set, how can one go wrong with a company that..
P/S Hey, you forgot to order the door handle gasket set when you ordered the weather strip gasket kit...... for your car..
Just saying...
Former Vendor
I believe the last year for the spring was 1974, 1975-1982 cars didn't use it.
Willcox
Willcox
Steve L.
73 coupe since new
Location: Las Vegas - Just stop perpetuating myths please.
I made mine out of hardware store brass tube and just flared it. Now i can see i didnt have any beads in mine like it should have - though i can bead tube now too that i have that tool. I was going to make some up for forum members here but im sure Wilcox will help u out and get u the right part. That should keep your wife happy.
Put the new tube in today, pretty straight forward. I did notice that the clamp at at the bottom of the hose really crimps it down to a smaller inside dia for drainage, and mine is the original hose/clamp setup. As soon as i loosened the clamp the water started draining.
Curious to see what plugged up the old hose i cut it open.
1. a pretty good sized rock was stuck inside the hose by the bottom clamp.
2. After three strip/repaint jobs in the last 40 years the hose was filled up with sanding material etc.
The nut will fit inside the hose.
Keep pushing the bolt in a little farther each time and let go to see how far the spring pops out. This way you can get the end of the spring near the end of the hose.
Keep the hose as straight as possible so you don't have to fight bends.
Steve L
73 coupe since new
