rear inner fender repair
Looking for tips on repairing the inner fender 'lips' on my 68. PO had larger tires on it and apparently hit the fenders at every bump in the road. Its just the inner side as you cannot see the damage from the side. Pieces are missing but mostly intact may not be explaining this too well but hopefully those who have had this problem can help. I'll add a pic to show how it looks from the side Thanks Paul btw the rears only
You should know by now that good photo's of your problem will be required. SO..please post good photo's...and also PLEASE do not get so close to the problem that I can see the atoms that make up the fiberglass. I need to see the problem 'somewhat' close up and one photo a bit further away so I know where the damage is located.
DUB
DUB
Dub its only the lip inside the rear wheel wells broken in several spots and missing in a couple- only on the top where tires hit- I'll try to get pic but thought it was a common problem with these cars. My pics are to show that the outside are normal looking see what I can do tomorrow
DUB
