"Opera" bulb above the heater duct, can I substitute it?
Hi All,
I'm replacing all my bulbs in the gauge cluster as I have it out to replace the clock and radio. I can't find the correct bulb that goes above the heater ducts, can I substitute it with anything else?
Thanks,
Sam
Thanks,
Sam
Also does the heater/ac control panel suppose to light up? I just finally drove my car in the dark last night and saw that all gauge lights work, trany light works, the opera light and wiper lights works - but nothing at the heater/ac panel. Thx
I used white LEDs this time.
With LEDs the climate controls are plainly visible, though, with the larger hole that the engineers missed (my theory - they're only paid to test drive during normal workday hours - trust me, this is an informed comment from being in the OEM industry). In any case, even with the standard bulb which I value the chance to put them back some day, the lighting would be better on the climate controls once you enlargen the lighting downfire hole. I stair-stepped up three drill bit sizes before I found the one that didn't make you squint to see the climate controls even with good vision.
Dave
Just a follow up, I found a store that had 2 in stock so I bought them both. Lakeside, I wish I saw your post before I put everything back together, great idea!
Street Rat,
Dave
Dave
Heater light
I don't believe it is suppose to, mine (79) has no light socket, just one for the trany, the heater--A/C were to be lit by the "opera" bulb
Brian
$31 for just one ebay bulb, WOW.....
