Anybody using Wilwood Brake Upgrade?
#41
Former Vendor
I'm really sorry guys...obviously I'm not trying to mislead you. Only using the tools at hand to show you the whys and hows. Having the wrong tool doesn't help.
I did post the info and image on the Wilwood facebook page tho in hopes of helping others.
After all that I sure hope someone doesn't come and show me the car is FS!
#42
PM sent. Ignatz and I aren't too far apart. Sure you don't want to make a trip to CA and swap some calipers? There's probably a few more in this area. It could be a "Caliper Swapping for Beer Tour" like the tours Lars used to do.
#43
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
carriljc (07-12-2017)
#46
Received 1,116 Likes
Am reluctant to change back, at least for a while. What is the downside here?
- Uneven wear
- Reduction of grip at the track
- might be a little grabbier?
with regard to the last, I was a little surprised at locking up my fronts at an autoX. Could the larger piston at the leading edge be creating a self-energizing effect?
- Uneven wear
#49
My conjecture is that the larger piston in the leading position pushes the front of the pad down harder leading to earlier binding. Just saying it seemed different when I switched to the illustration.
#52
Cliff the main reason for the different piston diameters is to prevent tapering of the friction material on the pads ( reasoning behind this, as friction material heats up it should have more grip until it reaches maximum temprature so the leading edge of the pad runs cooler than the trailing edge, by changing piston sizes, it reduces pressure on the hotter part of the pad.) You will see even more taper wear on your pads with the piston orientation reversed, there also might be a difference in the brake balance. Stock C2/3 Vettes tend to lock up their front brakes on extreme use, your front brake bias might actually be a little worse. In normal street driving, probably no difference, in panic stop situation....earlier front lock up giving loss of directional stability.
#53
1 Post
all the d8-6 caliper boxes are label left or right as well.
The supplied bolts were to long unless used with the supplied washer + a spring washer.
My front calipers were centered perfectly, the rears were slightly offset.
Last edited by waljr; 10-14-2014 at 05:24 AM. Reason: added d8-6 and bolt reference
#54
Former Vendor
#55
Finally started install yesterday. So far it has been a breeze. I initially bleed using a vacuum pump and mason jar, then I do a final bleed by pressurizing the master cylinder. The pads are not exactly centered in the rear caliper, about 0.03" off. The part I am a little concerned about are the bleed instructions that say for some installations (not mine I hope), the caliper needs to be rotated to the vertical position to remove all the air. I saw this after I installed the caliper. The line length and design will not allow for rotation. The caliper would need to be completely removed and wood blocks inserted between the pads for that to work.
I think what I will do on the other side is loosely mount the caliper, bleed then remove and bleed with it in the vertical and see if any additional air comes out. If it does, I will remove the other side and re-bleed. Pedal feels good however.
#56
Former Vendor
Only the rear calipers, if top mounted, will need to be removed. Or at least in some sort of vertical manner placing the bleeder nipple at the highest point.
#57
That's really handy when you also have to shim the calipers. I superglued the shims to the calipers. Truly an engineering marvel. And not in a good way.
#58
Would this be considered top mounted? I also included a pic of the rig I use to pressurized the master. So simple it is stupid.
#59
There is potentially a little air in the piston under the 'd' in Wilwood. The lower the trailing arm and the higher the front of the car helps I suppose. And rotating the caliper some. I didn't bother, my brakes are close to excellent pedal but possibly this is where the last bit of air resides.
___________
compliments on your pressurization rig. Think I will adopt it. How much pressure are you applying?
___________
#60
___________
___________
