A few 1977 vette questions.
Old 09-02-2014, 08:40 PM
vete76
vete76's Avatar
Default A few 1977 vette questions.
1. my window switch that mounts with 2 screws from underneath has both plastic mounts broken off. is there any thing short of replacing the whole console?
2. there is an antenna up/down switch on the left console side cover. when i removed the cover with switch, i didnt find any electrical plugs that would plug into the rear of the switch? am i missing something?
3. what year did the slotted mags become available?
thanks
fred
Old 09-02-2014, 09:26 PM
Frank_Nesta
Frank_Nesta's Avatar
thanks
fred
1. The easy answer is replace the black console piece. That said the only fix that comes to mind is to drill holes, counter sink holes to insert insert flat head screws from the top side, find a correct spacer length from the bottom, replace switch add washers and nuts. Paint screw heads to match. I think you would have to remove the console to do this work. Like I said replace the console.
2. 1977's did not have power antenna's. Some one added the switch for a power antenna. Probably not needed anymore.
3. I do not know, but some one on this forum will.
Old 09-02-2014, 09:42 PM
Peterbuilt
Peterbuilt's Avatar
Received 1,244 Likes on 965 Posts
#2 Could that be the switch for the rear defogger?
RPO C49
Old 09-02-2014, 10:29 PM
chucks
chucks's Avatar
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
Aluminum wheels were a option in 76.
Old 09-02-2014, 10:59 PM
Frank_Nesta
RPO C49
Vete 76, does the switch have a green light on it? If it does it is the rear window defogger.
Old 09-03-2014, 09:33 AM
vete76
vete76's Avatar
its a small flat togel switch w/ name plate , says antenna up/dn
Old 09-03-2014, 12:03 PM
Frank_Nesta
I then stick to my original post. Most power antennas can be wired to the radio for power on & power off. You can remove the marking and use the switch for another purpose or just leave it as is.
Old 09-03-2014, 12:23 PM
resdoggie
Had a 1976 L-82, 4-sp
Support Corvetteforum!
resdoggie's Avatar
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes on 925 Posts
Royal Canadian Navy
Aluminium wheels were first available as an option in 1973(?) but were dropped as an option due to casting issues. Please correct me if I'm wrong. They became available again in 1976 which has been pointed out already.
To A few 1977 vette questions.
Quick Reply: A few 1977 vette questions.
